So I notice that some low light images seemed a little dark around the edges. I took a bunch of pics (the two below for examples)..
The following images were taken in low tungsten lighting pointed at a wall (I realize its way underexposed, I used manual shutter for conformity). I first held the camera as you normally would then turned it upside down and took the same exact picture. What I see is each image having dark areas around the edges and turning the camera upside down show the pattern following, indicating to me that the darker areas stay in the same places on the sensor. Is this normal or do I have a defective camera?
*Edit - Indoor lighting was even.
right side up:
![]() | Byte size: ZERO | Content warning: NOT AN IMAGE |
upside down:
