Hi,
Can anyone tell me why I can only have 3 lines to my sig as when I look at others they seem to have lots more space. Are they pasting that detail manually everytime?
Attic Cream of the Crop 5,371 posts Likes: 101 Joined Nov 2006 Location: Rural Hampshire More info | Jan 05, 2008 12:03 | #1 Hi, Alby
kevin_c Cream of the Crop 5,745 posts Likes: 4 Joined Mar 2005 Location: Devon, England More info | Jan 05, 2008 12:47 | #2 |
Attic THREAD STARTER Cream of the Crop 5,371 posts Likes: 101 Joined Nov 2006 Location: Rural Hampshire More info | Jan 05, 2008 12:59 | #3 Thanks Kevin, If you look at my sig it has 3 lines yes? I can't add a blank line of another line with text either, I just don't understand it. Alby
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Jan 05, 2008 13:22 | #4 What kind of message are you getting? Jon
Attic THREAD STARTER Cream of the Crop 5,371 posts Likes: 101 Joined Nov 2006 Location: Rural Hampshire More info | Jan 05, 2008 13:30 | #5 If I add Alby on a new line I get: 1. Your signature contains too many lines and must be shortened. You may only have up to 5 line(s). Alby
Liam: Senior Member 533 posts Joined Nov 2006 Location: Guildford, UK More info | Jan 05, 2008 13:31 | #6 After your last line of your signature press the down key instead of enter and try entering something, should work. Liam.
Attic THREAD STARTER Cream of the Crop 5,371 posts Likes: 101 Joined Nov 2006 Location: Rural Hampshire More info | Jan 05, 2008 14:02 | #7 That worked for 4 lines but I can't do this: Alby
Liam: Senior Member 533 posts Joined Nov 2006 Location: Guildford, UK More info | Jan 05, 2008 14:43 | #8 Get to the start of the sentence "gear list" and then press back space. Liam.
Attic THREAD STARTER Cream of the Crop 5,371 posts Likes: 101 Joined Nov 2006 Location: Rural Hampshire More info | Jan 05, 2008 15:14 | #9 Not working, this is the best I can get Alby
Attic THREAD STARTER Cream of the Crop 5,371 posts Likes: 101 Joined Nov 2006 Location: Rural Hampshire More info | Jan 05, 2008 15:21 | #10 Sorted it, I had to go into editor mode as the code lines in there were too long making 7 lines. Thanks for all your help chaps Alby
Mike-DT6 Goldmember 3,963 posts Likes: 4 Joined Oct 2007 Location: The Jurassic Coast, Dorset, England. More info | Jan 08, 2008 11:15 | #11 I've never understood this. Some users have a lot more than five lines in their signatures. For example, Jon has eight lines in his signature.
tommykjensen Cream of the Crop More info | Jan 08, 2008 13:21 | #12 Mike-DT6 wrote in post #4658262 I've never understood this. Some users have a lot more than five lines in their signatures. For example, Jon has eight lines in his signature. I wonder what actually constitutes a 'line'. You and many other wonders. Including me. It seems that vb take font size etc into account when calculating lines. EDITING OF MY PHOTOS IS NOT ALLOWED
Mike-DT6 Goldmember 3,963 posts Likes: 4 Joined Oct 2007 Location: The Jurassic Coast, Dorset, England. More info | Jan 08, 2008 13:25 | #13 I'm glad it's not just me then!
tommykjensen Cream of the Crop More info | Jan 08, 2008 13:31 | #14 Another thing is that when using the wysiwyg editor then sometimes alot of bbcodes are left in even though they are not used but they are counted. So if you get an error try to switch to the standard editor so you see the actual bbcodes in the signature. EDITING OF MY PHOTOS IS NOT ALLOWED
Mike-DT6 Goldmember 3,963 posts Likes: 4 Joined Oct 2007 Location: The Jurassic Coast, Dorset, England. More info | Jan 08, 2008 13:50 | #15 I just type it out and add the formatting code manually. I have still got the original problem on here that I was going on about when I first joined! None of the formatting buttons or smileys work in the text editor. Also, it will frequently format all my text as one block, with no consistency in its behaviour, so I often type the formatting code too.
| Latest registered member is Thunderstream 1164 guests, 108 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
