Got a fast easy question. What do you set the options to when using Unsharp Mask?
Do you change those options under different circumstances?
Rad
Radtech1 Everlasting Gobstopper 6,455 posts Likes: 38 Joined Jun 2003 Location: Trantor More info | Sep 19, 2004 23:57 | #1 Got a fast easy question. What do you set the options to when using Unsharp Mask? .
Jesper Goldmember 2,742 posts Joined Oct 2003 Location: The Netherlands More info | Sep 20, 2004 01:16 | #2 There are no fixed settings for Unsharp Mask that work well on all photos. The effect also greatly depends on the size in pixels of the photo). Canon EOS 5D Mark III
Scottes Trigger Man - POTN Retired 12,842 posts Likes: 10 Joined Nov 2003 Location: A Little North Of Boston, MA, USA More info | Sep 20, 2004 03:03 | #3 Just to prove that there's no fixed setting... For a web image I start at 130%, Radius 0.3, Threshold 0 and adjust from there. For full size, it's more like 180%, radius 1.8, threshold 2, and adjust for the image. Bit of a difference from Jesper's starting points. You can take my 100-400 L away when you pry it from my cold, dead fingers.
aericj Goldmember 1,240 posts Joined Sep 2003 Location: Louisville, K USA More info | Sep 20, 2004 14:44 | #4 I usually start with 75%, .5 and 0 and adjust from there - usually in the range of 50-100%, .5 - 1.5, 0-5. Sometimes I apply at the lower end of the ranges twice if there is no adverse effect - especially when printing (up to 8X10). But then again I am also learning as well and got these settings from someone else's recommendation - they are definitely not scientific but they seem to work pretty well. Canon Ti5 w/ 18-135 IS STM, 70-300 IS, 85 1.8
MotorsportsPhoto Senior Member 428 posts Joined Nov 2002 Location: NE Ohio More info | Sep 21, 2004 11:32 | #5 My magic numbers have been 90, 2, 4. Making Racers Look Faster than They Really Are!
Xibalba Mostly Lurking 10 posts Joined Aug 2004 More info | Sep 21, 2004 19:17 | #6 Does anyone know of a good tutorial that explains exactly how USM works and what it does. I have read the quick guide over at The Luminous Landscape, but I was after something a bit more detailed to help me understand why the settings I am using are acheiving what I see in my image. Thanks.
| Latest registered member is Thunderstream 1211 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
