Thread started 07 Jan 2008 (Monday) 07:51
Off Camera Flash Questions
slimninj4
Jan 07, 2008 07:51 |  #1
I am looking into working off camera now with my flash. I do have a 430EX Canon. Can I use Nikon SB28DX and/ or a Vivitar 285HV with no issues (off camera)? Can I use ANY flash? All I will need is a pc cord and a hotshoe?
I look to mostly go with the strobist kit but I already have a stand, umbrella and softbox. Now I just need a flash. Eventually I will get a AB800 but I am looking for portability right now.
Also can the Nikon, Sunpak, Vivitar be my master and the 430EX slave off that too?
Canon 40D 5Dm3 || 24-70 L 70-200 2.8 IS2 100mm Macro 50mm 1.8 35 1.4
scot079
Jan 07, 2008 08:29 |  #2
Don't think in terms of master/slave with these flashes. That only works w/ Canon wireless E-TTL.
Using a sync cord, your camera can fire any of these flashes, but a flash can't fire a flash. With all those nice lights, I think you need a mix of wireless radio triggers (maybe some optical slaves to save money)
There are some triggers available on eBay for really cheap but I recommend Elinchrom Skyports, I know they work. For the adapters and cords, I'd go thru www.flashzebra.com (external link)
- Tim
www.timadkinsphoto.com (external link)
GEARandFEEDBACK
Curtis ­ N
Master Flasher
Jan 07, 2008 10:39 |  #3
This thread might answer some of your questions.
https://photography-on-the.net/forum/showthre​ad.php?t=308108
slimninj4
Jan 07, 2008 12:55 |  #4
Yes it did help alot Curtis. I see I need more equipment than I thought.
So my new list at BandH is Vivtar 285HV
Hot shoe to household
hot shoe for camera (XTI)
Impact umbrella bracket
16' sync cable
I have the stand and umbrella already. So that should set up up fine. In a few weeks I will get another umbrella and stand do slave my 430ex too. Great times ahead.
Curtis ­ N
Master Flasher
Jan 07, 2008 14:18 |  #5
slimninj4 wrote in post #4650842 (external link)
16' sync cable.
Typically people use a hotshoe to PC male adapter on the flash, a hotshoe to PC female adapter on the camera, and a PC cord in-between.
Nothing terribly wrong with a household connector, but you still need the right kind of adapter on the other end of the cord.
FlashZebra
This space available
Jan 07, 2008 17:08 |  #6
If you just want a sync cord to the Vivitar:
  • Camera hotshoe to PC adapter for the camera (to gain a PC port)
  • Long flash cord with a male PC on one end and a Vivitar connector on the other.
Few adapters, fewer issues.
If you get good cords, the proprietary Vivitar sync connector works fine. It feels like it it is not going to work, but it does.
HH connectors have a lot of good points, but the size of the connector is all out of proportion for hotshoe based flash units.
If you are looking to standardize on a common connector for all of your flash units from different manufactures check out mono miniphone cords. They are equally as reliable as the HH connector, also inexpensive, and the size of the connector is much more commensurate with the size of a hotshoe based flash.
In short, the upsides of the HH connector, without all that bulk and clunkiness.
Enjoy! Lon
rhys
Dis-Membered
Jan 07, 2008 17:29 |  #7
For that setup I'd go for an optical setup with a digital optical slave on the Nikon and Vivitar with the 430EX as the master (set on low power if you don't want it to flash the subject itself). That's the cheapest option but you have to get specific digital optical slaves. Ordinary optical slaves will be set off by the 430EX pre-flash.
An alternative would be to use an infra-red slave controller.
Rhys
The empire conquers yet more galaxies:
www.sageworld.co.uk (external link)
www.sageworld.org (external link)
www.sagephotoworld.com (external link)
Blog: http://360.yahoo.com/t​hunderintheheavens (external link)
Free cheese comes only in mousetraps
slimninj4
Jan 11, 2008 13:07 |  #8
Wow rhys what you just said, confused me. LOL.
I am happy to say I got my accessories in last night and tested it out. Works great. Now I will try and figure out how to use the 430EX as a fill light or hair light.
AB8ND
Jan 11, 2008 15:26 |  #9
Yes you can go with any flash off camera, I'd go with a radio control pc cords are just to hard to deal with and you know you don;t have a voltage problem
I use a couple of Sunpak 444d's and my 580 ex II when off camera
Jack
1,450 views & 0 likes for this thread, 6 members have posted to it.
891 guests, 118 members online
