Thread started 20 Sep 2004 (Monday) 17:57
Downloading images from cameras - Free Software *UPDATED*
OviV
Joined Oct 2003
Sep 20, 2004 17:57 |  #1
I have the 20D and 300D now and I would like that when my wife and I shoot an event that they get downloaded to the appropriate date directory and then the camera model within that directory.
I decided to write my own since I did not find a solution for this. This is a very simple application that takes the drive letter of the memory card a destination directory and you can decide whether it creates a directory for the date taken, camera model, or both. I am making it freely available here to the members.
You will need the .Net framework 1.1 in order to run it. It is available here if you do not have it:
http://www.microsoft.c​om …4D1E7CF3A3&disp​laylang=en (external link)
Also read the Readme file for some quick instructions. This is not a refined and idiot prove application since I wrote it for me. I will fix it up as I get time and if I get requests to do so. USE AT YOUR OWN RISK.
Download from here:
http://www.shareapictu​re.com/downloads/piclo​ader.zip (external link)
Regards,
Ovi
5D, 40D, Sigma 12-24mm f/4.5-5.6 EX, Sigma 15MM Fisheye,17-40 L, 24-105 L, 50 1.8, Tamron 28-75 2.8, Sigma 70-200 2.8, 70-300mm f/4-5.6 IS, 100-400 L, 300 F4 L, 580 ex, Sigma 500 Super DG Flash x 2, too much other stuff to list.
OviV
Joined Oct 2003
Sep 20, 2004 20:37 |  #2
Forgot to mention a couple of items:
1) This version works with JPG, CR2, and CRW files only.
2) With CRW files, they must have a thumbnail image with them for it to work. If you shoot raw with no jpg on a 10D or DRebel, this will not work for you. 20D raw with no jpg is o.k.
I will probably fix the issue with the CRW files in the future.
Ovi
tommykjensen
Gallery: 6 photos
Joined Mar 2004
Sep 20, 2004 23:50 |  #3
Cool.
So it will (can) create directory like this:
date/eos20d
date/eos30d
How about an option to switch the 2 parameters around so the directories will be created like this (which is the way I have my photos):
eos20d/date
eos300d/date
Is it visual basic?
EDITING OF MY PHOTOS IS NOT ALLOWED
OviV
Joined Oct 2003
Sep 21, 2004 04:33 |  #4
Tommy,
Yes, it saves them in date/canon_eos_20d. I will add the option of doing it the other way around. It is written in VB.NET.
Ovi
PaulB
Joined Apr 2003
Sep 21, 2004 07:17 |  #5
What a superb little application - very many thanks.
I may not use it all the time but for a memory card with a few images on each day and taken on a variety of dates it could be a real time saver, rather easier than looking at each image to see the date and then creating a folder etc.
Just an idea but if you are able to and have the time - why not enable a future version to do this from a already existing directory on a h/d or CD as well as from a card reader?
Again many thanks.
OviV
Joined Oct 2003
Sep 21, 2004 08:48 |  #6
O.K. I updated the file on the site. It will now let you select either Date/Camera or Camera/Date for the directory structure. As far as letting it copy files from any directory, I can easily do that except:
The application relies on EXIF information to retrieve date and camera model. As you modify files you may or may not save this information with them. I would have to write code to handle files that do not contain this information. We would need to figure out what to do with them.
Ovi
dialdn
Joined Aug 2002
Sep 21, 2004 08:48 |  #7
I use Downloader Pro with a 10D and a G2. Works well. Directories are photos/G2/Month/Day and photos/10D/Month/Day.
D
10D, G2
50 1.8, 70-200 2.8, 28-75 Tamron
420 Ex Flash
OviV
Joined Oct 2003
Sep 21, 2004 12:21 |  #8
Yeap, Downloader Pro will do it. Probably worth it if you need all the other features. I just wanted something simple.
Ovi
dialdn
Joined Aug 2002
Sep 21, 2004 12:50 |  #9
That's cool. I just thought I was missing something.
I think I will give your app a try.
D
10D, G2
420 Ex Flash
PaulB
Joined Apr 2003
Sep 21, 2004 14:04 |  #10
Ovi,
I tend to keep my downloaded files seperate and work on copies so in my case the EXIF info. would still be intact - however I do see the problem if you wanted to use PicLoader on altered files.
Again many thanks.
OviV
Joined Oct 2003
Sep 21, 2004 14:07 |  #11
No problem Paul. Make sure you download the latest version since I fixed a couple of minor bugs.
OviV
Joined Oct 2003
Sep 23, 2004 05:33 |  #12
I changed the application so that you can now specify a source directory, not just a drive letter.
Ovi
OviV
Joined Oct 2003
Sep 24, 2004 13:28 |  #13
Quick self-bump in case anyone is interested.
Ovi
Ragnar
1 post
Joined Sep 2004
Sep 24, 2004 14:43 |  #14
OviV,
I would love to use it - but get error msg at processing 1 of x:
Error: Index and length must refer to a location within the string. Parameter name: length
Can you help?
OviV
Joined Oct 2003
Sep 27, 2004 13:37 |  #15
Ragnar,
What camera are your pictures from? If 10D or DRebel, make sure that you are shooting RAW with at least small jpeg since the software relies on the jpg image to get the EXIF information. If you are using edited pictures that do not contain EXIF data, it will not work.
Regards,
Ovi
5,710 views & 0 likes for this thread, 10 members have posted to it.
1063 guests, 104 members online
