Thread started 10 Jan 2008 (Thursday) 16:30
Having a hard time to choose a lens.
eason_c
Jan 10, 2008 16:30 |  #1
I am looking to buy another lens, but I am having a hard time to choose which route I should go for:
1 - 10-20mm + 24-105mm F4L IS
2 - 17-55mm F2.8 IS
I will use the camera mostly for travel, and will shot indoor once awhile.
Thanks for the help
1Dmk4,14LII, 24LII, 35L, 17-40L, 24-70L, 50L, 85LII, 100L IS, 135L, 70-200 F2.8[COLOR=#ff0000]L [COLOR=black]II IS, 70-300L, 300L F4 IS.
sebr
Jan 10, 2008 16:41 |  #2
10-20mm + 24-105mm F4L IS + 70-200mm F4L IS is a great combo. I would go with option 1, especially if you can use the 430EX for indoor shots.
Sebastien
5D mkIII ; 17-40L ; 24-105L ; 70-200L II ; 70-300L ; 35L ; Σ85/1.4 ; 135L ; 100macro ; Kenko 1.4x ; 2x mkIII ; 580EXII
M5 ; M1 ; 11-22 ; 18-150 ; 22/2.0 ; EF adapter; Manfrotto LED
Benron Tripod; ThinkTank, Lowepro and Crumpler bags; Fjällräven backpack
ebann
Once an ugly duckling
Joined Jan 2003
Location: Chimping around Brazil since 1973! (Sometimes NYC)
Jan 10, 2008 18:49 |  #3
option 1 is actually 2 lenses. If you are going to buy only 1, then I'd get the 10-22. This way you're covered: 10-22, 17-70, 70-200. later you can replace your sigma with a 24-105/4 or 24-70/2.8.
Ellery Bann
Fuji X100
6D | Rokinon 14 2.8 | 50 1.4
1D Mk IV | 24-70 2.8L | 70-200 2.8L IS | 135 2L | 400 5.6L
eason_c
Jan 10, 2008 18:55 |  #4
ebann wrote in post #4676380 (external link)
Thanks, I was actually thinking about that as well, the question is F2.8 or F4 with IS. Was thinking I should have at least one F2.8 Standard zoom lens, it might be handy for some night shot when I travel.
JeffreyG
Gallery: 42 photos
Jan 10, 2008 19:03 |  #5
To my mind, the focal length range is more important than the aperture range for travel.
The 17-55 is an excellent travel lens because it allows you to pretty often wander about with just the one lens. When I had the 30D only I appreciated having a 17-55 for the ability to have a true 1 lens walkabout kit.
If I was carrying two lenses, then I also carried the 10-22.
To my mind, the biggest problem of the 24-105 on the smaller format is that it isn't wide enough as a 1 lens travel walkabout. Thus you pretty much always need to carry both the 10-22 and the 24-105.
OTOH, on the 5D the 24-105 is even better than the 17-55 on 30D since it is then both wider and longer. This setup was one of the draws to the 5D for me.
ebann
Joined Jan 2003
Jan 11, 2008 05:06 |  #6
eason_c wrote in post #4676417 (external link)
IS will save you from carrying a tripod in some circumstances. If you have shaky hands, it's very useful. F2.8 is heavier and a little longer. If you can afford it, get the 2.8 IS and never look back!
On the other hand, your general walk-around lens should be 2.8, thus later on get the 24-70/2.8L and get the 70-200/4L IS now (because it is the sharpest of all 4 models).
Ellery Bann
Fuji X100
JoYork
Jan 11, 2008 05:20 |  #7
If you plan to visit museums then the 17-55 IS is a must.
Some museums won't let you take a tripod in and the 17-55 will allow you to shoot handheld in low light with acceptable results. Hardest thing is getting the white balance right...
Jo
danielyamseng
Jan 11, 2008 07:55 as a reply to  @ JoYork's post |  #8
17-55 f2.8 IS is a great traveling lens but just make sure not to expose it to dusty environment:)
JoYork
Jan 11, 2008 10:13 |  #9
From what I gather, the dust won't affect the IQ if it's on the inside of the lens though.
Dust on the sensor will still be noticeable.
Jo
oaktree
Jan 11, 2008 11:17 |  #10
Since you already have a 70-200/4 IS, I would get the 17-55/2.8 IS. You'll be covered from 17 to 200 mm for travel, and I don't think you'll miss not having 55-70 mm covered. You could also bring your 50/1.8 for its f/1.8 just in case.
I travel with a 17-55 IS and 70-300 DO IS (and a 100/2.0) and have never felt I needed the 55-70mm focal length. Also, at a Rick Sammon seminar he said that if you're stuck with a not-wide-enough lens, take 2-3 shots and stitch them together as a panorama. Great suggestion! Your 17-55/2.8 IS will be wide enough for most shots and be very good indoor.
Too much stuff, not enough shooting time.
Canon T4i (2 lenses), Fuji X100s, Olympus OM-D EM-1 (3 lenses)
1,018 views & 0 likes for this thread, 7 members have posted to it.
960 guests, 137 members online
