If your camera is out of warranty and you want to hack into it:
http://qman.fotokala.ee …ad/PowerShotG7/index.html![]()
I imagine the G9 is similar in many respects.
DougF Member 146 posts Joined Sep 2007 More info | Jan 11, 2008 10:22 | #1 If your camera is out of warranty and you want to hack into it:
///M3Matt Member 243 posts Joined Aug 2007 Location: Philadlephia More info | Jan 11, 2008 15:21 | #2 wow....i certainly dont have the balls to take mine apart 5D Mark III l XTi l Elan 7E l G9 l Powershot SD780is
CJinAustin Goldmember 2,361 posts Likes: 2 Joined Jan 2008 More info | Jan 11, 2008 17:46 | #3 Permanent banDisassembly isn't my problem... but reassembly is another tike all together. - GEAR -
NooriB Hatchling 1 post Joined Aug 2009 More info | Aug 05, 2009 09:54 | #4 Doug F wrote in post #4680837 If your camera is out of warranty and you want to hack into it: http://qman.fotokala.ee …ad/PowerShotG7/index.html I imagine the G9 is similar in many respects. thanx for this link ...yesterday i'v recived a G9 AND COULDN'T DISSASSMBE IT...your picturs are so clear . do you have any other pictures of the other model ? Each moment of ur life is a picture which u had never seen before. And which ull never see again so enjoy & live life & make each moment beautiful....
Piet Senior Member 295 posts Joined May 2008 More info | Aug 05, 2009 11:31 | #5 CJinAustin wrote in post #4683827 Disassembly isn't my problem... but reassembly is another tike all together. Just do anything vice versa. Regards,
mteetank Member 65 posts Joined Jun 2009 Location: Lakeville, Minnesota More info | Boinnnnng....
BobsYourUncle Goldmember 1,532 posts Joined Jan 2008 Location: Calgary Alberta Canada More info | Aug 06, 2009 22:54 | #7 Somewhere in the '70's era shag carpet! Set Goals!! If you aim at nothing, you will hit it every time!
| Latest registered member is Thunderstream 1150 guests, 107 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
