Thread started 12 Jan 2008 (Saturday) 04:50
2 off camera flash units
davecropp
Jan 12, 2008 04:50 |  #1
I have a 580ex II and an older 420ex flash. Is it possible to set these up cheaply as portable flash units using cables and some form off hotshoe adaptor. I have the canon lead which is about 1.6m long but I want to put the heads on tripods at some distance away. I've looked at the infra red unit but think it is too expensive.
Canon 40d
dawnrogers
Jan 12, 2008 07:18 |  #2
Dave you can use one speedlite as the master on the camera and the second one as a slave off camera if that helps?? If you wnat them both off camera, skyports are pretty good, about £100 for the reciever and transmitter though....
Dawn
http://www.pivotalphot​ography.co.uk (external link)
My Blog (external link)
Curtis ­ N
Master Flasher
Jan 12, 2008 07:19 |  #3
This thread should help some.
https://photography-on-the.net/forum/showthre​ad.php?t=308108
rklepper
Dignity-Esteem-Compassion
Joined Dec 2003
Jan 12, 2008 12:13 |  #4
I have a 580EXII and 2 420EX. I set them up wireless with the 580 as master. It is extremely easy, ie nothing to it.
Doc Klepper in the USA
I
davecropp
Jan 12, 2008 13:04 as a reply to  @ rklepper's post |  #5
Thanks Guys.
I'd just got home with 2 KOOD flash slave units. Wished I read the Curtis N's post before hand as it is correct when it says they don't work with EX Flash. Can take them back on monday, but sounded a great option.
I did want to get both flashes off camera but I might be able to go with one on and one off. It's a group photo so I was hoping to have both flashes at about 45 degrees
Canon 40d
FlashZebra
This space available
Jan 12, 2008 13:19 |  #6
To get both off camera you could go with what I call "hybrid triggering". Part basic sync, part Canon infrared.
You would need a hotshoe adapter and cord going to the 580EX II (cannot use the built in sync port as it does not support Manual/Master mode). Then have the 580EX II act as a master to the 430EX.
Everything would need to be manual mode and your sync speed will be limited to about 1/100 sec (or so).
Another inexpensive option (not hybrid triggering) would be a hotshoe adapter and cord to the 430EX and an optical slave on the 580EX II (optical slaves will not work on the 430EX). The advantage would be higher possible sync speeds (to your cameras X-sync limit).
Enjoy! Lon
jrsforums
Jan 13, 2008 08:53 |  #7
davecropp wrote in post #4688546 (external link)
Thanks Guys.
Some advice on group photos....
http://super.nova.org …s/Photographing​Groups.pdf (external link)
John
davecropp
Jan 13, 2008 10:43 |  #8
Thanks again guys
The info from John on group photos looks pretty good.
We'll see how I go on.
Canon 40d
ebann
Once an ugly duckling
Joined Jan 2003
Location: Chimping around Brazil since 1973! (Sometimes NYC)
Jan 14, 2008 05:42 |  #9
FlashZebra wrote in post #4688600 (external link)
Enjoy! Lon
The OP's flash is a 420EX, no manual mode. I was wondering the same question. From reading a few threads, most pro have the following setup: wireless transmitter (e.g. Pocket Wizard) to the master flash (580EX) which triggers the rest via Canon infrared. But this works only with flash that has manual mode. For the 420EX, we would need E-TTL mode on the master flash, and using wireless, you would lose that. An alternative would be to use a Canon off-shoe cord on the 580EX and set that up on a flash-stand. This way you will be able to use your master in E-TTL mode, which will trigger the 420EX correctly. Feel free to correct me if I'm wrong. I'm beginning to learn this stuff!
Ellery Bann
Fuji X100
6D | Rokinon 14 2.8 | 50 1.4
1D Mk IV | 24-70 2.8L | 70-200 2.8L IS | 135 2L | 400 5.6L
davecropp
Jan 15, 2008 11:54 |  #10
i have the canon off camera lead but it's only 1.6m long and I was hoping to be a little further away from the flash than that. May have to go that way and see what happens.
Canon 40d
ebann
Joined Jan 2003
Jan 15, 2008 12:03 |  #11
Look here for what you want: http://www.michaelbass​.blogspot.com/ (external link)
He sells a hacked version of Canon's Off-Camera Cord with a mini-DIN extension cord in the middle (6ft, 10ft, 15ft, 30ft, 50ft, 100ft)
Ellery Bann
Fuji X100
2,001 views & 0 likes for this thread, 7 members have posted to it.
2237 guests, 133 members online
