Am I wrong when I tought that G1 takes a 12 bit pictures (RAW)? When using Yarc to convert pictures to TIFs, it doesn't make differ to use 8 or 16 bit mode. I allways get images at size 9MB. Why's that?
Thanks,
Stenu
Stenu Mostly Lurking 18 posts Joined May 2001 More info | Jun 14, 2001 05:23 | #1 Am I wrong when I tought that G1 takes a 12 bit pictures (RAW)? When using Yarc to convert pictures to TIFs, it doesn't make differ to use 8 or 16 bit mode. I allways get images at size 9MB. Why's that?
Jun 14, 2001 11:03 | #2 Stenu wrote: Am I wrong when I tought that G1 takes a 12 bit pictures (RAW)? When using Yarc to convert pictures to TIFs, it doesn't make differ to use 8 or 16 bit mode. I allways get images at size 9MB. Why's that? Thanks, Stenu SOmewhere (rec.photo.digital, or dpreview) it says the G1 can handle, or record, 10-bit images, but it only puts out 8-bit AFAIK. Chris Breeze (BreezeBrowser) and Bruce Henderson (Yarc) seem to only be able to get 8-bits out of the files, so maybe even 10-bits is dreamland. I've never heard of 12-bit, but I think the D-30 has higher image bits (?)
ega1 Member 126 posts Joined Apr 2001 More info | Jun 14, 2001 17:17 | #3 Stenu wrote: Am I wrong when I tought that G1 takes a 12 bit pictures (RAW)? When using Yarc to convert pictures to TIFs, it doesn't make differ to use 8 or 16 bit mode. I allways get images at size 9MB. Why's that? Thanks, Stenu As far as I know, nobody has figured out the Canon G1 RAW format enough to decode it without using Canon-provided code. So even though the G1 Raw format claims (and most probably is) 10 bits internally, the Canon API only transfers 8.
| Latest registered member is semonsters 1052 guests, 104 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
