OK MJ; you were right. With the 2X converter on it was like looking down a tunnel with very little light at the end of it; but hey! you don't know until you try it do you? I had 2 modelling lamps/flashes and the ring flash but still struggled to get enough light down the lens, the subject was deceased so I was able to slow the shutter speed right down to get more light to the sensor.
I then put two tubes on as well as the 2X converter, virtually black looking down the view finder; virtually impossible to focus. I had to put it on bulb and the shot below is a 45 second exposure, although with the extra tubes added there doesn't seem much increase in magnification. Both shots are pretty poor but it was just an experiment to see what happens when you do silly things. Strange thing though, usually when I have the 2X converter on; Zoom Browser usually reports the focal length at double the lenses true length (obviously I hear you saying) not with the MPe65, it reports it at 65mm with it on or without it. Don't think I'll bother again, the end results are pretty poor but there again I'm not the best macro photographer to start with.
Jesus; never realised my garage looked such a mess!
