Thread started 13 Jan 2008 (Sunday) 15:49
Wide angle flash..
EdATX
Joined Feb 2006
Jan 13, 2008 15:49 |  #1
I'm looking at getting the Sigma 500 DG. I'll soon have the Tokina 12-24. I know the Sigma comes with a panel to use it up to 17mm. How would I go about using the flash on anything wider? Diffuser? My search really didn't help me on this one..
-ed
http://www.photo-mojo.net (external link)
e ­ r ­ y ­ k
Jan 13, 2008 16:03 |  #2
with a FL at 12mm, its very hard to get an evenly lit picture with a flash. you are going to experience light falloff on the outer edges.
i dont think a diffuser will help too much, but the wide panel thing that you pull out on most flashes helps it a bit.
Canon EOS 5Dmk3 //
doidinho
Jan 13, 2008 16:38 as a reply to  @ e r y k's post |  #3
Is that up to 17mm on a FF camera? If so the 12-24 only goes down to a 19mm FF eq so you will be fine with the on board panel.
Robert McCadden
My Flickr (external link)
MM (external link)
5DMKII, Rebel xti, 24-105 f/4L, Canon 70-200 f/4L, Canon 17-40.
braduardo
Jan 13, 2008 16:41 |  #4
If you have a decent surface to bounce off of, that will probably do the most good. Once in a while I will drop the diffuser panel on my flash and bounce off the ceiling. It takes some power, but helps give fairly even light.
:rolleyes: ----Brad---- :rolleyes:
www.nybergstudio.com (external link)
40D: EF 17-40 f4 L ---- EF 70-200mm f4 L ---- EF 50mm f1.4 ---- EF 85mm f1.8
cdifoto
Don't get pissy with me
Jan 13, 2008 16:42 |  #5
12mm on 1.6x is 19.2mm angle of view. You're good to go there. You should be bouncing flash anyway. ;)
EdATX
Joined Feb 2006
Jan 14, 2008 14:28 |  #6
Yeah, I guess i forgot out the crop factor involved!
-ed
1,341 views & 0 likes for this thread, 5 members have posted to it.
Wide angle flash..
1040 guests, 107 members online
