Thread started 14 Jan 2008 (Monday) 10:21
Explain This Lighting
whuband
Jan 14, 2008 10:21 |  #1
I shot this photo of an obviously excited Jaguar fan on Saturday night. The Bud Zone sign is "Budweiser Red" as seen in the woman's hair. I used AWB as my setting.
I have shot "neon" type lighting many times (cityscape type photos) but never paid close attention to see if any of the red shifted color.
I know someone can enlighten me on the particular gas in this tube and how to capture it in the original red.
Thanks.
IMAGE: http://i43.photobucket.com/albums/e357/WhiskeyHotel/IMG_3854.jpg
1D4, 6D, 7D2, Sony a6000 with Sony16-70, Rokinon 12mmf2, Canon lenses: 17-40L, 17-55 f2.8, 10-22, 50mm 1.4, 85mm 1.8, 70-200mm IS 2.8, 300mm 2.8 IS, 580EXII (3), 430EX, Alien Bees.
René ­ Damkot
Jan 14, 2008 11:16 |  #2
The letters shift color because they're overexposed.
If you shot Raw, try lowering exposure.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
whuband
Jan 14, 2008 11:37 as a reply to  @ René Damkot's post |  #3
Thanks Rene
Wilt
Jan 14, 2008 11:50 |  #4
Rene is right, but PP of RAW would not fix this photo, as the adjustment would affect the overall shot (unless you did some fancy work with masks!).
PP would cause underexposure of your friends, while improving the redition of the sign.
This situation is fixed at the time of shooting, by not only judicious choice of f/stop, but also very judicious selection of shutter speed -- so that the shutter+f/stop capture the Bud sign at proper brightness to render it in true red color.
ebann
Once an ugly duckling
Joined Jan 2003
Location: Chimping around Brazil since 1973! (Sometimes NYC)
Jan 14, 2008 12:10 |  #5
Please do show your results as to how you managed to fix your picture! It's very educational!
Ellery Bann
Fuji X100
6D | Rokinon 14 2.8 | 50 1.4
1D Mk IV | 24-70 2.8L | 70-200 2.8L IS | 135 2L | 400 5.6L
René ­ Damkot
Jan 14, 2008 12:17 |  #6
Wilt wrote in post #4700841 (external link)
I should have mentioned that :p
Curtis ­ N
Master Flasher
Jan 14, 2008 13:48 |  #7
I agree with Rene' about the cause of the problem. However, the red channel is most likely clipped so bad that it can't be saved via RAW converter adjustment.
ebann
Joined Jan 2003
Jan 14, 2008 16:46 |  #8
Curtis N wrote in post #4701568 (external link)
So what is the technique needed in order to capture the correct exposure *and* the correct red tonality? I'm most curious to learn...
Ellery Bann
Fuji X100
Wilt
Jan 14, 2008 17:10 |  #9
ebann wrote in post #4702712 (external link)
Meter the lights and manually set the aperture and f/stop. Then turn on the flash and shoot away with flash in ETTL!
Curtis ­ N
Master Flasher
Jan 14, 2008 18:43 |  #10
Reducing exposure to capture the lights without clipping would get their proper color. But they are so much brighter than the wall they're mounted to, that wall will likely be rendered nearly black when you dial back the exposure that far.
It's extremely difficult to expose a light source without clipping and still get decent exposure of the surroundings.
1,600 views & 0 likes for this thread, 5 members have posted to it.
1474 guests, 123 members online
