Thread started 14 Jan 2008 (Monday) 13:58
CRW (camera raw) and Photoshop CS
HighLife
Jan 14, 2008 13:58 |  #1
Hey guys...just discovered the CHDK firmware for my A570 and was playing with it a bit. Shot some pics in CRW and removed them from my card via a card reader.
I have Photoshop CS with the 4.3.1 Camera RAW update, however whenever i try to open it in PS it says its " not the right kind of document ". I downloaded the plugin i could find and the update from PS itself..however, it still wont open it up....did i miss something?
I know i can convert CRW to DNG file, the file is bigger then the CRW straight from my camera...however, is this ok to do? Changing from CRW to DNG to Jpeg?
Canon 590IS/CHDKMy Flickr (external link)
Jon
Joined Jun 2004
Jan 14, 2008 14:13 |  #2
You actually need to convert the RAW from the hack to something else before PhotoShop will read it; the hack doesn't produce an "official" Canon RAW format.
Jon
Cocker Spaniels
HighLife
Jan 14, 2008 14:22 |  #3
SO i have to go from CRW to DNG?
Ugs
Jan 14, 2008 14:24 as a reply to  @ HighLife's post |  #4
Yes - no problem with DNG.
Jon
Joined Jun 2004
Jan 14, 2008 14:25 |  #5
Yep. From the CHdk wiki (external link), you need to use a program that's been specifically developed for the conversion.
Jon
Cocker Spaniels
HighLife
Jan 14, 2008 14:26 |  #6
any difference or is there a way to go from CRW to normal RAW, or will it be equal to going from CRW to DNG?
Thanks, ya i was reading the wiki, but i thought new update CS would open up CRW file.
Jon
Joined Jun 2004
Jan 14, 2008 14:32 |  #7
PSCS will only open Official CRW files, not this "unofficial" one. There's no normal RAW that is used in all cameras; that's why Adobe's pushing DNG. Every Canon camera to date has used a somewhat different, and mutually incompatible (in some quirky way) RAW format even though they may have used the same CRW (original) or CR2 (later) extension.
Jon
Cocker Spaniels
HighLife
Jan 14, 2008 14:39 |  #8
Jon wrote in post #4701916 (external link)
Gotcha...i guess its not big deal going from CRW (unofficial) to DNG quality wise? Im using DNG for Powershot 1.1.4 to convert CRW to DNG.
Thanks for the info...been playing around with photoshop and dng...seems there is more info and more adjustments then Zoombrowser and Jpegs. I just thought what the hell, might as well try the CHDK firmware...i love the live histogram =)
Jon
Joined Jun 2004
Jan 14, 2008 14:40 |  #9
Nope. DNG's supposed to preserve all the capabilities inherent in the original RAW, but in a "standard" file format that won't go out of date.
Jon
Cocker Spaniels
HighLife
Jan 14, 2008 14:44 |  #10
i noticed that it actually a larger file....CRW shot was 8.7megs, converting the same file to DNG it came out 14.2megs.
Now, if someone would come out with a firmware that shots DNG so this could all be avoided =)
Jon
Joined Jun 2004
Jan 14, 2008 14:46 |  #11
That's what Adobe wants camera makers to do . . .
Jon
Cocker Spaniels
HighLife
Jan 14, 2008 14:49 |  #12
Jon wrote in post #4701996 (external link)
ohhh now i understand...its a battle....since every camera company has their own form of RAW, adobe brought in DNG to create a standard format. However, companies still want to use their own format, which creates this type of format war ....arrgg cant we all get along? :D
Jon
Joined Jun 2004
Jan 14, 2008 14:51 |  #13
Same as lens mounts. Each company designs the data format to best take advantage of their cameras' sensor designs and (in the case of Canon Picture Styles) software engineers' ideas. And, as you've seen, the RAW file's smaller than the equivalent DNG file, which makes a difference in card capacity.
Jon
Cocker Spaniels
HighLife
Jan 14, 2008 16:11 |  #14
the white balance seems to be really off in Photoshop, i guess there is no way to sync it with my camera's white balance so it shows up the same?
btw DNF4PS-2 Beta is working for the 570 =)
BBoi
Jan 14, 2008 19:42 |  #15
Fingers crossed for good old Adobe... i'm still waiting for JPg2000 to become an adopted standard for the web, it's compressed results are FAR superior to regular JPg. That coupled with a standard DNG and I recon togs will be in heaven :)
Quick Online Paint Prog for on-the-spot editing (external link) (requires flash)
>> Visit my Site (All Gold Photography Uk) All advice on the rebuild gratefully recieved. (external link) <<
All done with a Canon A640
8,534 views & 0 likes for this thread, 4 members have posted to it.
2115 guests, 104 members online
