DDan wrote in post #4704036
I only use the meter for a starting point and a rough one at that. I use the histogram for fine tuning.
For example, if you're shooting a subject in a big snow field, unless you calibrate your camera to a proper white balance first, then your image will come out underexposed. The histogram in that case, may show a pretty high singular peak in the middle region. However in "reality" the exposure should've been taken so that the histogram shows the high peak towards extreme right.
If you were "correcting" your exposures just based on what the histogram tells you, in above example instance, you will get severe under-exposure. Opposite is true when shooting against a dark background, etc.
This is why histogram really isn't very useful, other than to show the distribution of bright pixels once the photo is taken, properly exposed or not.
See what I mean?
