Does Photoshop create a history of what has been done to an image, so that you can go back to it and remind yourself what you did to it to make such a mess of it?
Mike
Mike-DT6 Goldmember 3,963 posts Likes: 4 Joined Oct 2007 Location: The Jurassic Coast, Dorset, England. More info | Jan 14, 2008 17:21 | #1 Does Photoshop create a history of what has been done to an image, so that you can go back to it and remind yourself what you did to it to make such a mess of it?
atomick Member 98 posts Likes: 1 Joined Jan 2006 Location: San Francisco Bay Area More info | Jan 14, 2008 17:25 | #2 Histories are only tracked within a session. If you want a more permanent record, you need an application whose history is fully tracked like Lightroom. Photoshop writes temporary data to the scratch disk, changing the original file...Lightroom simply keeps an instruction set of what you've done and applies it nondestructively. If you simply want to have options open in terms of "dialing back" changes you've previously made, the trick in Photoshop is to make heavy use of layers and adjustment layers...and, sadly, saving incremental file changes as you work. 5D | 15 f2.8, 17-40 f4L, 24-70 f2.8L, 70-200 f4L
Mike-DT6 THREAD STARTER Goldmember 3,963 posts Likes: 4 Joined Oct 2007 Location: The Jurassic Coast, Dorset, England. More info | Jan 14, 2008 17:33 | #3 Okay, thanks.
Damo77 Goldmember 4,699 posts Likes: 115 Joined Apr 2007 Location: Brisbane, Australia More info | Jan 14, 2008 17:41 | #4 |
Mike-DT6 THREAD STARTER Goldmember 3,963 posts Likes: 4 Joined Oct 2007 Location: The Jurassic Coast, Dorset, England. More info | Jan 14, 2008 17:43 | #5 Thanks Damo. I think I'll do that, then leave myself a note somewhere else to remind me about the note in the file info section!
PhotosGuy Cream of the Crop, R.I.P. More info | Jan 14, 2008 20:37 | #6 I think I read somewhere that PS can write history to a text file. Not sure about that. FrankC - 20D, RAW, Manual everything...
Mike-DT6 THREAD STARTER Goldmember 3,963 posts Likes: 4 Joined Oct 2007 Location: The Jurassic Coast, Dorset, England. More info | Jan 14, 2008 20:41 | #7 Thanks Frank, I'll have a look into that.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Jan 15, 2008 02:04 | #8 Photoshop can definitely write its edit history to a text file, i've seen it done. Google will tell you how. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Mike-DT6 THREAD STARTER Goldmember 3,963 posts Likes: 4 Joined Oct 2007 Location: The Jurassic Coast, Dorset, England. More info | Jan 15, 2008 02:08 | #9 |
RodBarker Senior Member 464 posts Joined Apr 2005 Location: Hervey Bay Australia More info | Jan 15, 2008 04:20 | #10
Mike-DT6 THREAD STARTER Goldmember 3,963 posts Likes: 4 Joined Oct 2007 Location: The Jurassic Coast, Dorset, England. More info | Jan 15, 2008 04:27 | #11 |
PhotosGuy Cream of the Crop, R.I.P. More info | Jan 15, 2008 09:15 | #12 Thanks, Rod! FrankC - 20D, RAW, Manual everything...
| Latest registered member is Monkeytoes 1369 guests, 174 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
