Thread started 15 Jan 2008 (Tuesday) 23:33
580EX II Master, 580EX Slave, and Pocket Wizards
ayotnoms
Perfect Anti-Cloning Argument
Joined Jan 2005
Jan 15, 2008 23:33 |  #1
Feeling rather doltish because I can't figure out if it's me or how I've got things set up.
Configuration: PW receiver connected to 580EXII which in turn is set to Master. The 580EX is set to slave. PW transmitter on the camera.
Problem: 580EX II fires as expected. The 580EX in slave mode however does not fire until after the shutter has closed...at least using shutter speeds that ranged from 1/200 sec to 1/25 sec. I want them to fire simultaneously.
As an aside, when I mount the 580EX II on my camera, both flashes fire just fine.
OK, so what simple, well known precaution am I not taking?
Steve
[URL="http://photograp​hy-on-the.net/forum/showpost​.php?p=1267612&postcou​nt=17"]Gear
jptsr1
Jan 15, 2008 23:39 |  #2
ayotnoms wrote in post #4712915 (external link)
i don't think the canon whatchamjigie works when the 580 is off camera unless you are using one of their cords. not sure though but im sure someone else will chime in soon enough.
J.
Et Facta Est Lux
Flickrexternal link
tmr
Jan 16, 2008 01:11 |  #3
I agree with jptsr1. I think you'll need another PW for the other 580.
I did something similar recently. I got a couple of digital peanuts to drive my old SLR flashes. Worked fine with my 580ex wireless selector switch in "off". I then switched to "master" to add in a few 430ex as slaves. The flashes with the digital peanuts didn't fire in sync with the Canon flashes (they did fire just not at the right time). Either the preflash is different in master mode or the communication between the master and slave throws the peanuts off.
Lotto
Jan 16, 2008 02:43 |  #4
Sounds like your master 580 II is not in manual mode. When both flash are in ETTL mode, when you press the pilot botton on the master, the slave will fire a second later.
5D, 24-105L, 70-200L IS, 85mm Art, Godox
tim
Light Bringer
Jan 16, 2008 04:26 |  #5
You can use wireless ETTL, with one flash in master and one in slave, that doesn't use pocket wizards but you get ETTL for automatic exposure. Or you can use a PW on the camera and each flash, with everything in manual, you have to meter yourself.
tim
Light Bringer
Jan 16, 2008 04:27 |  #6
btw if you're using PWs and all manual then the 580 II is a very expensive flash to use as a dumb slave.
Lotto
Jan 16, 2008 05:10 |  #7
tim, one PW can be connected to the master 580, the master will fire and control the power output of the slave EXs (exclude the 420EX). I believe that's what the OP is trying to do, but the master 580 II must be in manual mode with Ratio turned on.
PacAce
Joined Feb 2003
Jan 16, 2008 07:35 |  #8
tim wrote in post #4713842 (external link)
Tim, that's neither here nor there. If people have more than one Speedlite, there's no reason why they can't be used with PWs to trigger them. Heck, that would apply even if they only had one flash! They already have the flash and the money has been spent. So there's no reason they can't use it anyway they wish. It's not like they're wearing the flash out and will need to replace them soon. If that were the case, then yes, a warning about the flash being very expensive as a dumb slave used that way would be warranted. But it's not, is it? ;)
...Leo
MDJAK
Jan 16, 2008 07:47 |  #9
I agree with Leo.
Unfortunately, I'm probably dumber than antonym on this stuff. Sheesh.
me
tim
Light Bringer
Jan 16, 2008 08:19 |  #10
Lotto wrote in post #4713909 (external link)
Yeah that's possible, but kindof defeats the purpose of pocket wizards doesn't it?
PacAce wrote in post #4714290 (external link)
Yeah if you have them already it's a good idea, i'm just pointing it out for other people that are reading that thread that you don't need expensive flashes if you use them in manual mode.
ayotnoms
Joined Jan 2005
Jan 16, 2008 08:52 |  #11
Let's say you want to take a photograph of birds in a birdbath under a large tree that requires a lighting boost. Is it not reasonable to use a remote flash connected to a PW? That's really all I am trying to do; trigger a flash from a remote position. Isn't that one application for a flash -- even an expensive one like the 580EX II?
Steve
FlashZebra
This space available
Jan 16, 2008 11:09 |  #12
Steve,
If you connect the Pocket Wizard via the PC port on the 580EX II, the needed Manual-Master mode is disabled. My "stab" guess is that this is what you are doing (the PW comes with a cord that will connect to the 580EX II PC port).
This means that you cannot trigger your "master" 580EX II to start the process to allow it to trigger your other compatible Canon flash units via the Canon infrared system. I call this "hybrid triggering" (part fundimental sync triggering, part Canon infrared triggering).
If you connect the Pocket Wizard to the 580EX II via the hotshoe you can regain the manual- master function on the 580EX II.
Enjoy! Lon
Mr. ­ Clean
Jan 16, 2008 11:23 |  #13
I hear this a lot and I actually feel somewhat stupid by making a counterpoint to the all mighty TIM.
And that's no joke! You're one of the most experienced and most helpful people on POTN.
I don't think the 580II, or a pair of them and Skyports or Pocket Wizards are a bad idea. Are there cheaper options? Hell yes there are! However everything comes with a cost in compromise. Power, compatability, reliability, features, and portability.
Mike
some shots @ Zenfolio (external link)
ayotnoms
Joined Jan 2005
Jan 16, 2008 11:59 |  #14
FlashZebra wrote in post #4715369 (external link)
Steve,
Enjoy! Lon
Thanks Lon. I appreciate the feedback.
Let me re-phrase and maybe you can tell me if I'm off track.
To fire the 580EX II remotely, I can connect the PW to the PC port and it will work fine although it will not allow me to use the flash as a master to control other flashes.
If I connect the PW via the hotshoe, I can once again have wireless control over multiple flashes.
Thanks again everyone for the excellent feedback.
Steve
PacAce
Joined Feb 2003
Jan 16, 2008 12:31 |  #15
ayotnoms wrote in post #4715628 (external link)
Yes, now you have it right. :D
But, remember, you need to have the master in Manual mode and the slaves must have manual mode capability with their output set manually via the master or on the slaves themselves.
...Leo
14,418 views & 0 likes for this thread, 14 members have posted to it.
1214 guests, 136 members online
