Ever since I got a 5D, I've used my XT (and 40D when I had it) for more reach. I'm starting to wonder, would a 1.4x TC on a 5D produce better images than just using a 1.6x Crop with higher pixel density? Anyone have any experiences?
drjiveturkey Senior Member ![]() 542 posts Joined Mar 2007 Location: Leesburg, VA More info | Jan 16, 2008 15:39 | #1 Ever since I got a 5D, I've used my XT (and 40D when I had it) for more reach. I'm starting to wonder, would a 1.4x TC on a 5D produce better images than just using a 1.6x Crop with higher pixel density? Anyone have any experiences? It all started as a hobby with a Rebel XT & KIT lens. $5K worth of equipment & $0 of income later, all I have to show for it is a harddrive full of pictures and priceless memories!! Yeah it's still worth it
Denny G Goldmember ![]() 1,870 posts Likes: 5 Joined Jul 2004 Location: On the border - US/Mexico More info | Jan 16, 2008 16:01 | #2 Why? was your 40D a telephoto camera?
braduardo Goldmember ![]() 2,630 posts Likes: 1 Joined Jun 2006 Location: Minneapolis, MN More info | Jan 16, 2008 16:04 | #3 Well, a teleconverter costs you 1 stop of light, and will degrade the image at least a little bit. For max pixels on target, the 40D will still get more pixels where you want them.
Jan 16, 2008 16:24 | #4 Ok I am confused....assuming you are using the same lens on the XT and the 5D how is the XT giving you more reach....the focal length is the same you just seeing less of the image with the XT. So if you shoot with the 5D and crop the photo in photoshop then you can end up with the same shot as with the XT. The only diffrence I see is the 5D having more Megapixles so you could blow the image up more. 70D, 24-70EF 2.8L USM, 70-300EF USM IS, 24-105 f/4L USM
Mr. Clean Cream of the Crop ![]() 6,002 posts Likes: 3 Joined Jul 2005 Location: Olympia, Washington More info | Jan 16, 2008 16:27 | #5 A 1.4 TC degrades image quality always. Sometimes it's not entirely evident, sometimes it's seemingly nonexistent, sometimes it obvious. All depends on the lens. Long story short, if you wanted the "longer-focal-length-in-35mm-equivalent" I would go with the 40D route (heh, maybe not the XT route though). Mike
Jan 16, 2008 16:30 | #6 Denny G wrote in post #4717109 ![]() Why? was your 40D a telephoto camera? tjrenegade wrote in post #4717241 ![]() Ok I am confused....assuming you are using the same lens on the XT and the 5D how is the XT giving you more reach....the focal length is the same you just seeing less of the image with the XT. So if you shoot with the 5D and crop the photo in photoshop then you can end up with the same shot as with the XT. The only diffrence I see is the 5D having more Megapixles so you could blow the image up more. Someone correct me if I am wrong about this because I getting really confused with all these post about crop.... No, but it has a higher resolution than if I had just cropped out the center image on a 5D. Sure I can always get a longer lensm for the 5D, but I use to have a 400 f/2.8 IS and 500 f/4 IS and they're not a walk in the park lens. It all started as a hobby with a Rebel XT & KIT lens. $5K worth of equipment & $0 of income later, all I have to show for it is a harddrive full of pictures and priceless memories!! Yeah it's still worth it
SkipD Cream of the Crop ![]() 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Jan 16, 2008 16:39 | #7 tjrenegade wrote in post #4717241 ![]() Ok I am confused....assuming you are using the same lens on the XT and the 5D how is the XT giving you more reach....the focal length is the same you just seeing less of the image with the XT. So if you shoot with the 5D and crop the photo in photoshop then you can end up with the same shot as with the XT. The only diffrence I see is the 5D having more Megapixles so you could blow the image up more. Someone correct me if I am wrong about this because I getting really confused with all these post about crop.... If you made a shot with the same lens on an XT and on a 5D from the same location, then cropped the 5D shot to the same image size as that on the XT, you will have far fewer pixels in the 5D shot. The cropped 5D shot will have only about 5 megapixels, compared to 8 megapixels for the XT image. Skip Douglas
JeffreyG "my bits and pieces are all hard" ![]() More info | Jan 16, 2008 17:02 | #8 Straight up cropping, the XT will probably beat the 5D because of the 8MP vs. 5 MP. Five MP is low enough that this will degrade resolution on large prints. My personal stuff:http://www.flickr.com/photos/jngirbach/sets/
BTBeilke Senior Member ![]() 827 posts Likes: 1 Joined Aug 2005 Location: Bettendorf, IA USA More info | Jan 16, 2008 17:03 | #9 drjiveturkey wrote in post #4717284 ![]() The 300 f/2.8 IS on the other hand is light enough to use without a monopod or tripod. For me it's the perfect compremise btwn focal length and weight. I don't have the 300 f/2.8 so I can't give you any personal experience. But, I have read on this board that the 2x TC was specifically designed/tuned for use with the 300 f/2.8 and therefore performs better with that lens than any other. Maybe someone else can confirm this? Blane
ed rader "I am not the final word" ![]() More info | Jan 16, 2008 17:05 | #10 drjiveturkey wrote in post #4716993 ![]() Ever since I got a 5D, I've used my XT (and 40D when I had it) for more reach. I'm starting to wonder, would a 1.4x TC on a 5D produce better images than just using a 1.6x Crop with higher pixel density? Anyone have any experiences? you'd be better off with a crop camera for reach. and you can also use a tc with the crop camera. http://instagram.com/edraderphotography/
BogongBreeze Senior Member 353 posts Joined Oct 2005 Location: Australia More info | Jan 16, 2008 17:08 | #11 It doesn't sound as if there's a clear answer to your question. Perhaps you could take some comparison shots and post back here (assuming you have the 1.4x converter and lens). Miriam
GyRob Cream of the Crop 10,206 posts Likes: 1413 Joined Feb 2005 Location: N.E.LINCOLNSHIRE UK. More info | Jan 16, 2008 17:23 | #12 ed rader wrote in post #4717510 ![]() you'd be better off with a crop camera for reach. and you can also use a tc with the crop camera. ed rader yep i agree here and sold my 5d parlty because of fps and mostly to get the 40d 1.6crop reach with 10mp and still be able to add a tc . "The LensMaster Gimbal"
ed rader "I am not the final word" ![]() More info | Jan 16, 2008 17:32 | #13 BogongBreeze wrote in post #4717536 ![]() It doesn't sound as if there's a clear answer to your question. Perhaps you could take some comparison shots and post back here (assuming you have the 1.4x converter and lens). my answer was pretty clear...i used the 5d and 30d in tandem just like i recommended http://instagram.com/edraderphotography/
defordphoto MKIII Aficionado 9,888 posts Likes: 3 Joined Oct 2002 Location: Pacific Northwest More info | I have the 300 f/2.8IS and both the Canon 1.4x & 2x TC's. This is one amazing lens. Many claim it's the sharpest lens in the world. That, of course, could be argued time and time again on forums across the land. defordphoto | Celebrating the art of photography®
braduardo Goldmember ![]() 2,630 posts Likes: 1 Joined Jun 2006 Location: Minneapolis, MN More info | Jan 16, 2008 17:46 | #15 JeffreyG wrote in post #4717483 ![]() Straight up cropping, the XT will probably beat the 5D because of the 8MP vs. 5 MP. Five MP is low enough that this will degrade resolution on large prints. The TC+5D on a quality zoom lens like the 70-200 f/2.8 will be close to the 70-200 native on the XT. The TC on an L prime (300/4, 400/5.6 or one of the supertelephotos) and the 5D+TC will be better IQ than the XT native. I'm failing to see how this would be. Adding in any TC is going to cause some degradation. It may not be much, but it WILL be some. You can't even AF the 400 f5.6 w/ a TC on the 5D, and you wouldn't get quite as many pixels on target anyways (560mm vs 640mm FOV).
y 1600 |
Log in Not a member yet?
Latest registered member is JTravLog 708 guests, 103 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 |
