Thread started 16 Jan 2008 (Wednesday) 19:44
Calumet Genesis kits?
MrChad
Joined Aug 2004
Jan 16, 2008 19:44 |  #1
I have a small livingroom but a fairly high large white ceiling. I was thinking of buying a nice neutral back drop and nice pair of lower wattage starter strobes w. stands.
I was thinking of getting some AlienBees, however, anyone have any opinion of the Calumet Genesis kits? Clearly targeted at the beginner but the kits looked to have everything one would need to get started.
Having a fairly small room for now I was thinking of getting the 200w twin kit. I also liked the idea that the Genesis lights can fit some Elinchrome accessories.
I kaNt sPeL...
[Gear List]
swalter
Joined Jun 2005
Jan 22, 2008 01:28 |  #2
I was looking for reviews as well, but haven't found any. They certainly look good on paper.
http://www.calumetphot​o.com/item/CF0502K1/ (external link)
-Scott
http://scwalter.smugmu​g.com/ (external link)
Atomic79
Jan 22, 2008 16:56 |  #3
I just got email from Calumet announcing these today so they are really new. Unless they are a repackage of some other light it's going to be a little bit before reviews start popping up.
After going to both Calumet's and Elinchrome's sites and doing some image comparisons I think the Genesis200 is a repackage of the D-Lite2.
No matter how slow the film, Spirit always stands still long enough for the photographer It has chosen. Minor White
elwood58
Joined Dec 2004
Jan 22, 2008 17:31 as a reply to  @ Atomic79's post |  #4
The Elinchrome D-Lite2s sell for $300 each. If this is really a repackage of their Strobe, it is a very good deal. The dish assembly looks different though, so I could not tell if accessories are cross compatible.
50D and a bunch of lenses (external link)
chris ­ sorensen
Jan 23, 2008 19:07 |  #5
I was in Calumet today and played with these. Pretty darn nice for the price. Digital adjustment, audible beep on recycle, seemed fairly sturdy. Tested the recycle time on min to max and was pretty much in line with the 1-3 second the specs say. Which is higher than the .8 seconds the specs for the DLite 2 says, so maybe they're not rebadges. They did say they take Elinchrom accessories.
www.chris-sorensen.com (external link)
Cars0n
Joined Nov 2005
Jan 23, 2008 19:39 |  #6
These are ridiculously tempting. I've been toying with the idea of studio lights and even though I don't think I'm quite ready, I'm almost ready to jump on these just to play with.
Body: 40d w/grip, 40d w/o grip
Glass: Sigma 10-20, Sigma 30 1.4 Tamron 28-75 2.8, Canon 85 1.8, 70-200 2.8L IS
Light: 550 EX, 285HV
magicmikey
Jan 23, 2008 21:15 |  #7
The only problem I see is that the accessories for Elinchrome strobes, which these use, are more expensive than those of Alienbees. Other than that, they look quite nice.
Michael
nobleatelier
Jan 24, 2008 14:50 |  #8
Hi.
This is my first post here.
I just picked up a Genesis 2 kit last night. Haven't had a chance to pop it yet, but initial impressions: it is a very robust kit for an entry level kit. In fact, it really is on the higher end of an entry level kit, akin to a prosumer kit, if you will.
The light stand is a very sturdy stand, telescoping to 10 feet. It is much beefier than the thin Impact stands that come with some kits. The twist knobs are substantial, and you don't get the impression that you'd strip the screw threads if you turn too hard.
The umbrella is a convertible 45" brolly. It feels stable and of decent material. It comes with a nice sheath to put it in.
Finally, the strobe head itself. Well made, nice form factor, solid build. Digital readout, push buttons, audible alerts. The modeling light and flash tubes are user replaceable. The strobe uses Elinchrom mounts. If you want to use softboxes you'd have to purchase a Speedring and softbox. They don't come together, unfortunately. You can us Calumet softboxes with it, as well.
So, MrChad, I think you'd have a very capable setup on your hands. In a small room you might have too much power on your hands. I was using two 100 watt-second strobes in softboxes turned down to about 1/2 and 1/4 power. Never full power, and I used a small bedroom for shooting. Then I only used one and had enough light spill onto my background. Now I have the 200 watt-second kit. I know I won't be using this at full power.
nobleatelier
Jan 24, 2008 14:52 |  #9
elwood58 wrote in post #4758940 (external link)
Yes, they are a repackage of the Elinchrom D-Lite series. I researched them to purchase a while ago, but decided on the Calumet Travelites. I found out about the Genesis series while on hold about to buy a Travelite and then reconsidered in order to research the Genesis.
steveathome
Jan 24, 2008 15:03 |  #10
These are fan cooled the D-Lites are not.
Edit: for the price they look too good to be true, looks like a possible great starter kit.
jptsr1
Jan 24, 2008 22:14 as a reply to  @ steveathome's post |  #11
im trying to decide between these and the beginner bee kit. cant find any reviews though.
J.
Et Facta Est Lux
Flickrexternal link
RichNY
Jan 24, 2008 23:27 |  #12
The D-Lites are much nicer than the Alien Bees. For one they are digital. They are also color consistent from top to bottom of the scale, solidly built, and have pop to pop consistency.
TMRdesign and I spent 3 hours in the B&H lighting department today and came away knowing that these models are the ideal alternative to Alien Bees for people wanting a better light at low cost.
Nikon D3, D300, 10.5 Fisheye, 35 f/1.4, 50 f/1.4, 85 f/1.4, Zeiss 100 f/2, 105 f/2.5, 200 f/4 Micro, 200 f/2, 300 f/2.8, 14-24, 24-70, 70-200, SB-800x4, SB-900, SU-800, (3) Sunpak 120J (2) Profoto Acute 2400s,Chimera softboxes, (4)PW Multimax, (6) C-stands, (3) Bogen Superbooms, Autopoles
chris ­ sorensen
Jan 25, 2008 00:08 |  #13
RichNY wrote in post #4777738 (external link)
Are you referring to the D-Lites or the Calumet Genesis? Or both?
MrChad
Joined Aug 2004
Jan 25, 2008 09:53 as a reply to  @ chris sorensen's post |  #14
Sounds like these may become the new shiz-nitz in cheapy home lights...sweet.
I kaNt sPeL...
[Gear List]
chammer2
Jan 25, 2008 11:14 as a reply to  @ MrChad's post |  #15
I am new to these light kits and am also looking at the Genesis kit. I have questions on basic setup. Are these lights continuous? It has a 5 volt sync cord that I'm assuming is used when using wirelessly (does that change the continuous lighting?). Does the cord connect to the camera and then both lights? It has a built in photo cell that allows wirelesss flash syncronization. What accessories are required to allow that? Sorry if these questions are so basic.
132,763 views & 0 likes for this thread
Latest registered member is txlaflash
751 guests, 243 members online
