I have been looking at getting some ND filters and the whole confusing issue has raised a few questions (apologies for so many questions):
From reading other posts I think I would like to get Hitech filters. Are the 85mm Hitech filters going to be wide enough in their respective holder (2-slot) to avoid vignetting on my 17-40mm f/4 L at 17mm on a 20D? I'm referring to the 2-slot holder.
Would the same set-up vignette on a Canon 10-22mm at 10mm?
Would the same set-up (using the 17-40mm L) vignette on a full frame sensor camera (not important at the moment, but I'm planning ahead)?
If I have a (77mm) circular polarizer on my lens, can the adapter ring, filter holder and filter(s) fit to that and work properly, or do I have to use a (larger) circular polarizer and adapter in front of the filters (i.e. so that the light goes through the polarizer before the filters)? I don't want to go and buy an expensive 77mm CPL, then find I can't use it between the lens and filter holder!
Is the MkII aluminium holder the best one to get for price and performance? £46 seems a lot of money to me, but I'll get one of these if it is stupid not to. If there are better holder choices, can you recommend one please?
Does anyone happen to know the price of an 85mm Hitech 10-stop ND filter? I can't find a price for those. I would like one of those, plus a standard filter kit (0.3, 0.6 and 0.9)
I am thinking of just buying some filters first, without a holder, and hand-holding them. I have read quite a few people saying that they do this. Is it a sensible idea, or just a good way to get poor results and scratched filters?
Do you meter through gradient ND filters, or put them on after metering? I presume you don't meter through non-gradient ND filters, or do you?
Thanks in advance for any words of wisdom on these matters!
Mike
