Shooting wrote in post #4735408
I saw a photgrapher with a flash on a bracket but it was fixed at a 45 degree angle and had a white index card rubber banded to the back of it but he was using it inside and outdoors, fixed at 45 degrees everywhere he went with the white card on the back..what effect would he have had?
The effect of this is to show the world that he doesn't understand light. I love the index card/rubber band method, and recommend it often, for ceiling bounce. The card just throws a little light forward to fill shadows and create catchlights. The optimum flash head angle depends on the ceiling height and distance to subject. Outdoors, all it does is waste light (and batteries).
I saw another using the lightsphere outdoors and he looked like a bum and the bride was so upset at her pictures
You can't light the entire universe with a hotshoe flash unit. The only effective way to use flash outdoors is to leave it naked so it lights your subject, not everything else. People who don't understand that shouldn't be shooting weddings.
I have used the lumiquest soft box on my flash with bracket before but not at a wide angle like 24mm..would it spread the light out to cover that?
Sorry, you only get two questions per post.
I have used the Lumiquest Softbox with lenses as short as 17mm (on a 20D) with satisfactory results. But you don't need to take my word for it. Just shoot a blank wall or ceiling with it, and look at the levels throughout the image in Photoshop. Shoot the same thing without the softbox and with the flash properly zoomed for the lens, and compare the results.
