jennyb wrote in post #4743956
A lot of people are complaining about battery life issues on the A570. Mostly though it's that the LOW BATTERY indicaor comes on, not camera malfunctions. Some think it's connector problems in the battery compartment. You might make sure you have enouh tension to keep the batteries in contact with eachother, the door and the spring congtact.
When this happens is the rest of the camera functional? Before snapping a picture can you zoom the lens to make sure you have battery power? If you switch the lcd display off can you view through the viewfinder and snap a picture without getting the blank record? The fact it usually happens when both flash and lcd are on does make one wonder about the power, but maybe you always shoot with the LCD on.
Thanks for your reply and attention. I think it should be related to power, but my problem is completely different than others with low-battery indicator (I never received that). I tested it again carefully, and here is what is going on:
As long as I shoot with LCD off, there is no problem.
After the first shot with LCD on, and using flash,
- The LCD shows blank (it is like I am looking at a completely black scene)
- icons are still on the LCD (So LCD is not dead)
- I can zoom in/out
- even when I zoom in using digital zoom, the noises become to show on the screen!!! (but it is still like I'm looking at a black scene)
- If I press the shutter to focus, the yellow led begins to blink. And shooting result to blank picture.
- If I press the LCD button and turn it off (and then turn it on), then the camera works OK again.
- If I go to play mode, and come back the camera becomes OK also.
