I would like to convert about 100 raw images in RAW format to jpeg and need to do this quickly. Do I have to select each image individually or can I do the whole batch at once? if i can do the wholes batch at once how is this done
Thanks Antony
alpine62uk Member 136 posts Joined Aug 2004 More info | Sep 28, 2004 15:26 | #1 I would like to convert about 100 raw images in RAW format to jpeg and need to do this quickly. Do I have to select each image individually or can I do the whole batch at once? if i can do the wholes batch at once how is this done 5d Mk 3
yb98 Goldmember 2,625 posts Likes: 36 Joined Feb 2003 Location: Paris More info | Sep 28, 2004 15:32 | #2 it depends on which soft you use. Best DPP Threads
JLSPhoto Member 165 posts Joined Sep 2004 More info | Sep 28, 2004 17:45 | #3 With EOS Viewer Utility, simply select all and convert the batch.
Oct 02, 2004 08:36 | #4 Thanks 5d Mk 3
| Latest registered member is Thunderstream 1012 guests, 110 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
