Hello, I currently have an sd700 and I'm thinking about getting an s3. The question about the s3 is, will I have manual control over the apertures and shutter speeds? Thanks.
splunkinoob Member 110 posts Joined Mar 2007 More info | Jan 21, 2008 12:38 | #1 Hello, I currently have an sd700 and I'm thinking about getting an s3. The question about the s3 is, will I have manual control over the apertures and shutter speeds? Thanks. The basics - Rebel XT, 18-55, 50 f1.8
CanonGuy Member 98 posts Joined Jun 2006 Location: Vancouver, BC, Canada More info | Jan 21, 2008 21:05 | #2 Yes. 300 HS
Jan 22, 2008 00:29 | #3 Canon Guy wrote in post #4753154 Yes. Thanks, I see you have the s3 and an sd series camera. Which do you prefer? The basics - Rebel XT, 18-55, 50 f1.8
whuband Goldmember 1,433 posts Likes: 84 Joined Jul 2007 Location: Jacksonville, Florida More info | Jan 22, 2008 18:54 | #4 splunkinoob wrote in post #4754324 Thanks, I see you have the s3 and an sd series camera. Which do you prefer? I've had both and you can't go wrong with the features on the S3/5, as long as you don't have to put it in your pocket. 1D4, 6D, 7D2, Sony a6000 with Sony16-70, Rokinon 12mmf2, Canon lenses: 17-40L, 17-55 f2.8, 10-22, 50mm 1.4, 85mm 1.8, 70-200mm IS 2.8, 300mm 2.8 IS, 580EXII (3), 430EX, Alien Bees.
CanonGuy Member 98 posts Joined Jun 2006 Location: Vancouver, BC, Canada More info | Jan 22, 2008 23:48 | #5 splunkinoob wrote in post #4754324 Thanks, I see you have the s3 and an sd series camera. Which do you prefer? The S3 for sure just because of everything you can do with it and that 36-432 reach. But I find myself using the SD more and more simply because it's so easy to carry around - just drop it in my pocket and go. If you end up getting an S3/5, keep your SD700 around and you'll have all the camera you need (short of adding a dslr). 300 HS
RyanMcDede Member 80 posts Joined Jan 2008 Location: florida More info | Jan 23, 2008 00:00 | #6 i have used both. the s3is is better then the s5. i have seen a lot more noise with the s5, the s3 in my opinion is superior Canon 30D w/ BG-E2 battery grip
Antz_Marchin Senior Member 341 posts Joined Apr 2007 Location: St Catharines, Ontario More info | My friend has the SD850 IS and my S3 is still far superior in my opinion. He does have higher resolution but the S3 still does great in that department and has much more atristic freedom. I'm getting a DSLR soon but will still never get rid of my S3.
| Latest registered member was a spammer, and banned as such! 2126 guests, 104 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
