Thread started 23 Jan 2008 (Wednesday) 09:24
Need Help with Photo I Love
King ­ of ­ Canada
Jan 23, 2008 09:24 |  #1
I need a little help with the below image. It was taken when I was playing around with my 50 1.8, and I really ended up loving it. It has a very Norman Rockwell feel to it.
The problem was that because I was just playing around I did not take into account the background. I am pretty confident in my PP abilities in lightroom, but do not have a ton of experience with editing heavily in photoshop.
Does anybody have any ideas on how I might fix the background to not be so busy, or even get rid of all of the background without looking too overdone?
Here's a link to the full sized file.
http://chrislewis.smug​mug.com …ry/3810376#2369​05616-O-LB (external link)
cosworth
I'm comfortable with my masculinity
Jan 23, 2008 09:35 |  #2
Here's a rookie way. Easy if you will.
Open the image. Gaussian or lens blur the entire image to match a background you like. Don't overdo it.
then using the history brush paint away the blurring on your subject. Use a fairly hard brush, zoomed in around the edges. the once deon, go a bigger on the brish and erase away the center fo the subject.
You are going to blur, then paint in the undo. Simple and somewhat effective.
people will always try to stop you doing the right thing if it is unconventional
Full frame and some primes.
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jan 23, 2008 09:53 |  #3
History states aren't saved & you might want to make a change later, so...
Duplicate the layer.
Blur it.
Add a Layer Mask, Layers> Add layer mask / "reveal all" or "hide", & paint on that to show the blur on the bottom layer.
More: Post #9:
Airport runway shoot
cosworth
Jan 23, 2008 09:56 |  #4
Frank, you're right on this one. If he can blur he can add a layer.
PixelMagic
Jan 23, 2008 10:30 |  #5
Personally I like the depth of field the way it is so I would take a different approach.
Add a Hue/Saturation adjustment layer, desaturate to -20 and reduce Lightness to about -30. Then take a soft black brush and paint on the mask to bring back the subject. You can even do this artistically by varying brush opacity to bring more light to the face and eyes and less to other parts of the body....somewhat like creating a chiaroscuro effect.
Alternately you can use a Render > Lighting filter to create a spotlight (preferably blue to counter the yellow color cast), the mask it off and paint back in the spotlight in the desired areas.
King ­ of ­ Canada
Jan 23, 2008 11:00 |  #6
Thanks for the suggestions. I'll give both a shot when I have a chance and post back with my results.
PixelMagic
Jan 23, 2008 12:15 |  #7
Here's a proof of concept demonstration of using a Hue/Sat adjustment layer. Could still be improved but this should give you the basic idea.
IMAGE: http://img179.imageshack.us/img179/9090/236905616ocopyv2fb4.jpg
King ­ of ­ Canada
Jan 24, 2008 14:20 as a reply to  @ PixelMagic's post |  #8
Ok, so I decided to just clone the dark space in the background.
Comments are welcomed. :)
shannyD
"...in too much trouble"
Jan 24, 2008 14:23 |  #9
i think its a good effort. b ut it makes me feel strange. like the baby is playing a lone with no one, or nothing there.
i think you would be better off with blurring the BG more.
subtle_spectre
Jan 24, 2008 16:15 |  #10
Okay...I had a go at it:
Full-size here: http://scottcphotograp​hy.com/potn/236905616-O.jpg (external link)
Scott
Vista owner...and user  :p _______________
Gear
www.scottcphotography.​com (external link)
TeeTee
Jan 24, 2008 17:19 |  #11
shannyD wrote in post #4773880 (external link)
Shanny makes a valid observation here guys.
As much as the background is too busy, don't kill it and turn the photo into a child playing in an empty room/space. I think the presence of the people in the background is important but should be dulled a little.
5DmkII & 85L
and a bunch of other glass that rarely sees the light
King ­ of ­ Canada
Jan 24, 2008 18:55 |  #12
subtle_spectre wrote in post #4774720 (external link)
Wow, that's really great!
FlexiPack
Jan 24, 2008 19:01 |  #13
Scott that's some fantastic bit of cloning work there!!
Body: 450D
Lenses: Sigma EX 18-50mm 2.8 Macro; EF 50mm f/1.8 MKII; EF 100mm Macro f/2.8; EF 70-300mm IS; Zeiss S 135mm f/3.5;
Accesories: 430EX; Vivitar 285; Kenko DG Extension Tubes;
subtle_spectre
Jan 24, 2008 19:10 |  #14
FlexiPack wrote in post #4776078 (external link)
You get good at when you are only a mediocre photographer!!:lol: Thanks....
Scott
Gear
2,305 views & 0 likes for this thread, 8 members have posted to it.
971 guests, 159 members online
