After reading through the SLA battery pack threads on the Flickr Strobist website time and again, I decided to build a couple of my own. One down, one to go.
I used the 6 volt 4.5Ah SLA battery with a panel mount fuse holder, a power switch and RCA jack to connect to the Quantum module for the 540EZ.
While I was at the local electronics component store, I found a 6 volt floating charger and the mating 2.5 x 5.5mm panel mount receptacle so to charge the battery, all I have to do is plug in the charger!
Here is a link to a few pictures of my project:
s226.photobucket.com/albums/dd265/mt_stringer/Battery%20P...
![]() | HTTP response: 404 | MIME changed to 'image/gif' | Byte size: ZERO | PHOTOBUCKET ERROR IMAGE |
Hope you find this info helpfull.
Mike
