Why should minimum shutter speed for long lenses be driven by the crop factor or "equivalent focal length?
It is often said that the minimum shutter speed for long lenses should be adjusted for the "crop factor". For example, we frequently see advice such as the following:
The minimum shutter speed for a 200 mm telephoto lens should be adjusted from 1/200" up to 1/320" for a camera with an APC or APS-C sensor (crop factor of 1.6).
I have never seen this issue questioned before, but I have come to believe that the sensor size has nothing to do with the minimum shutter speed required for long lenses. In fact it is difficult to find anything about the crop factor of sensors that is of any concern beyond the following facts:
a) the higher the crop factor, the longer is the "equivalent focal length".
b) the higher the crop factor, the smaller is the captured field as compared to a full frame sensor.
Looking deeper, we find that "Equivalent focal length" has some interesting implications!
1) There is a widespread belief that perspective changes with focal length (false).
2) Conventional wisdom says that the longer the focal length, the more likely it is that the image qualilty will suffer from lens motion.
However, we know that perspective is actually controlled by the position of the viewer in relation to the scene. The focal length of a lens may force the photographer to move in closer or step back further, and it is only in that sense that the focal length affects the perspective. See http://www.earthboundlight.com …istance-focal-length.html![]()
So, wherever the term "equivalent focal length" is used, there is the implication that we should have to use a faster shutter speed - because of the crop factor.
In my opinion, the "crop factor" or "equivalent focal length" is a bug-a-boo that has mistakenly become the basis for a higher shutter speed requirement, when in fact the only thing that changes as a result of the crop factor is how much of the scene is being captured (how big the capture field is).
Another thing that should be kept in mind is that each lens has an actual focal length, and that actual focal length is what it is - regardless of what size sensor lies in the focal plane.
Your comments are invited.
