Thread started 24 Jan 2008 (Thursday) 20:01
New Member with S3 IS -Questions
Papa ­ Roe
Jan 24, 2008 20:01 |  #1
I just found this forum. I had my S3 for over a year now and love the quality of the outdoor picures it takes. However, most of my indoor pics are grainy and just poor quality. :~( Any suggestions?
NOsquid
Jan 24, 2008 20:56 |  #2
Low light sucks with all compacts. You can use the flash, buy a slave flash to bounce, or just nip the problem in the bud and get a DSLR.
danpass
Jan 24, 2008 21:01 |  #3
Tripod (even if just a little desktop one) and force the ISO down to 200 and less.
should do it (besides using a dedicated flash)
Dan
Gallery (external link) | Gear/Feedback
NOsquid
Jan 24, 2008 21:06 |  #4
Tripod works as long as nothing is moving.
gjl711
Jan 24, 2008 21:09 |  #5
A slave flash is your best bet. The only way to manage the noise is lower the ISO which means your going to need more light. A slave flash bounced off a wall or ceiling is going to give you a very nice even light.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Canon ­ Guy
Jan 24, 2008 23:17 |  #6
Avoid Auto if possible, use at least P mode so that you can control the ISO.
300 HS
S110
Rebel XSi: EF-S 18-55 IS, EF-S 55-250 IS, EF 50 f1.8 II, 430 EXII
peterpogi2006
Jan 24, 2008 23:38 |  #7
and download a free noise reduction software!
Papa ­ Roe
Jan 25, 2008 07:26 |  #8
Thanks for the advice. The minute manual that came with the camera is useless. Please tell me more about the slave flash, any recommendations? I do have a tripod. When I take indoor pictures they lack dimension. Will the slave flash resolve this problem?
Insidious1
1 post
Jan 25, 2008 07:37 as a reply to  @ Papa Roe's post |  #9
I find indoor shots to be good. I dont know what modes you use it in but you could try using "P" mode.. or use "AV" and try it around 1/100 and keep the iso below 200.. i usually keep it at 100. Could you post some samples with the efix data?? That would make it easier to advise you...
;-)a
Michael.
edit: Also.. You should have got 2 manuals with the camera.. an advanced and quick start manual.. The advanced one must be available online as a pdf somewhere...
gjl711
Jan 25, 2008 08:08 |  #10
Papa Roe wrote in post #4779367 (external link)
Here is Canon's flash, the HF-DC1:
http://www.adorama.com​/ICAHFDC1.html (external link)
A slave flash will go far in solving your problem. It provides a lot of light and used properly can really give a nice soft light illuminating the whole room. There was a post here a while back that did a pretty good job showing the differences between shooting with no flash and different flash setting with a slave flash. Check out:
https://photography-on-the.net …php?p=2609292&p​ostcount=4
::Gear::
NOsquid
Jan 25, 2008 12:24 |  #11
I don't understand?
Jon
Joined Jun 2004
Jan 25, 2008 12:51 |  #12
Papa Roe wrote in post #4776500 (external link)
Post an example or two. The suggestions made above can help certainly, but only if they apply to the problem as you perceive it.
Jon
Cocker Spaniels
Papa ­ Roe
Jan 25, 2008 19:09 |  #13
OK here's a couple of my not so good indoor shots.
[IMG]http://picasaweb.googl​e.com …photo#515068234​9878424002 (external link)
[IMG]http://picasaweb.googl​e.com …photo#515068318​3102079858 (external link)
I hope that I uploaded these picture correctly.
Jon
Joined Jun 2004
Jan 25, 2008 19:15 |  #14
Picasa doesn't let you link in that way. The second one is showing a shallow DoF, which is making things look soft, if that's what you mean.
Jon
Cocker Spaniels
Papa ­ Roe
Jan 25, 2008 19:18 |  #15
Nope I must of did something wrong. I click o the insert image icon, but it only gave me a URL address link, and you can see what happen.
2,268 views & 0 likes for this thread, 9 members have posted to it.
2429 guests, 104 members online
