Thread started 25 Jan 2008 (Friday) 18:18
CS3 Help - Pin register two images
JFK
Jan 25, 2008 18:18 |  #1
In Scott Kelby's CS2 book in the chapter on bracketing with camera raw he describes how to drag and drop one image onto another using the move tool and holding down the shift key. I have tried this method with CS3 but no matter what I do the two images will not align or "pin register" as he calls it.
Is there something that I am missing here or is there another method for CS3?
John
www.johnkrepp.net (external link) Canon 5D, 40D, 20D, EF 17-40 f4L, EF 100-400 f4.5-5.6L, EF 24-105 f4L, EF 100 f2.8 Macro, Feisol CT-3401 Tripod, Feisol CM-1401 Monopod, Manfrotto 488RC2 head, Kenko 1.5 TC
Mark001
Jan 25, 2008 20:43 |  #2
This works the same in CS3 as in CS2. After you finish the drag and drop operation, do you see both the "Layer 1" and "background" layers?
- Mark
1D Mark III, 20D, 400 F5.6, 24-105 F4 IS, 17-40 F4, 70-200 F2.8 IS, 100 F2.8 Macro, 1.4xII, 580EX II
SilverHCIC
Location: Swimming, cycling or running ... somewhere in California
Jan 26, 2008 00:14 |  #3
JFK wrote in post #4783155 (external link)
...move tool and holding down the shift key
... Should be working for you. As long as you are holding down the shift key as you drag one copy of an image onto another, they are automatically pin registered.
"It's easy to find your bike in transition when you're the last one out of the ocean ... it's no fun being lost at sea :rolleyes:."
René ­ Damkot
Jan 26, 2008 08:06 |  #4
...If the images are the same size. Otherwise it won't work.
Copy-paste will work as well.
Obviously the images need to be taken off a tripod to begin with ;)
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
beto57
1 post
Apr 15, 2008 19:49 |  #5
John
I have the same problem...and the answers didn't clear it up
Damo77
Apr 15, 2008 19:51 |  #6
I don't know if this will help ...
Sometimes if I'm trying to align two layers, I change the blend mode of the top one to "Difference" then use the arrow keys to nudge the layer into place.
Damien
Website (external link) | Facebook (external link)
Damo77
Apr 15, 2008 19:55 |  #7
I barely know squat about photography, but here's something I know ...
If your bracketed images aren't lining up perfectly, maybe you're not using a cable release when taking the shots? The act of physically pressing the shutter button can move the camera ever so slightly, enough to bugger up your efforts.
Damien
printguy
Apr 15, 2008 20:07 |  #8
The images have to be identical so far as content, position in the frame and dimensions (pixels, not any other measurement). If these conditions are not met then putting one point in register will only move other points out of register.
Wayne
5D; 7D; 40D; 400D; S90; Canon EF-S 10-22, EF-S 17-55 IS, EF 24-70 f/2.8L, EF 24-105 f/4L IS, EF 70-200 f/4L, EF 70-300 f/4.5-5.6 DO IS, EF 50 f/1.8 II, EF-S 60 f/2.8 macro, EF 100 f/2.8 macro, EF 200 f/2.8L II; Domke stuff: F-2, J-1, F-4AF, F-5XB, F-802; Think Tank Retrospective 20; Gitzo 2941 w/Kirk BH-3; more other stuff than I care to admit to
ssim
Joined Apr 2003
Apr 16, 2008 18:52 as a reply to  @ printguy's post |  #9
While it is preferential that the images be taken with a tripod they do not actually have to be. They do however have to have some complimentary content that can be lined up. I have taken many a shot freehand making sure that I do not recompose other than change exposure. While they are close they are not identical. It is from the same camera and I do not do any cropping prior to this.
I would shift drag the layer from one image to the other. Shift or CTRL click on both layers in your layers palette so they are both actively selected. Go to Edit-Auto Align Layers. I always use the Auto option (first one) and it does an amazing job.
1,786 views & 0 likes for this thread, 8 members have posted to it.
643 guests, 122 members online
