Hello
I am using * to focus on my 30D ( CF4-1) , then what button do I use for FEL ?
Thanks for your help
Neil B.
neilbui Member 110 posts Joined Nov 2006 Location: Southern CA More info | Jan 28, 2008 22:06 | #1 Hello
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Jan 28, 2008 22:14 | #2 The only button you can use is the "*" button. So you'll need to make a choice, Im afraid, between either using it for focusing or for FEL. ...Leo
gooble Goldmember 3,149 posts Likes: 1 Joined Jul 2006 Location: Mesa,AZ More info | Jan 28, 2008 22:27 | #3 Are you using the built-in flash or external?
Jan 28, 2008 23:49 | #4 I use 430EX Flash unit
gooble Goldmember 3,149 posts Likes: 1 Joined Jul 2006 Location: Mesa,AZ More info | Jan 29, 2008 03:25 | #5 I'm not sure the focus point plays any part in the pre-flash flash exposure check. You can set it to use evaluative or center weighted avg.
SESmithJr Senior Member 566 posts Likes: 2 Joined Jan 2008 Location: Florida More info | This has been driving me nuts! Say I'm in Av or Tv mode. If I meter off one part of a scene with the flash up, and hit the * button to lock the exposure, when I go to recompose the exposure settings change. Why does it do this? I thought Flash Exposure Lock was supposed to lock in the exposure. It doesn't matter what CFn4-1 option I have my 40D set to, it does the same thing. Am I missing something here? -Steve
Bob_A Cream of the Crop More info | Feb 01, 2008 22:27 | #7 Sonno wrote in post #4833847 This has been driving me nuts! Say I'm in Av or Tv mode. If I meter off one part of a scene with the flash up, and hit the * button to lock the exposure, when I go to recompose the exposure settings change. Why does it do this? I thought Flash Exposure Lock was supposed to lock in the exposure. It doesn't matter what CFn4-1 option I have my 40D set to, it does the same thing. Am I missing something here? Because with the flash up the * button is for "flash exposure lock", not "exposure lock". When the flash isn't being used it is for "exposure lock". Bob
Bob_A Cream of the Crop More info | Feb 01, 2008 22:28 | #8 gooble wrote in post #4806025 I'm not sure the focus point plays any part in the pre-flash flash exposure check. You can set it to use evaluative or center weighted avg. I believe that for ETTL the focus point was used. It isn't used for ETTL II. Bob
Bob_A Cream of the Crop More info | Feb 01, 2008 22:32 | #9 gooble wrote in post #4804729 Are you using the built-in flash or external? Now this makes me wonder; what if you're using a 580ex, camera set to M and you use "*" to focus. Is there a need for FEL in this situation? Having the camera in M and using a 580EX does nothing to eliminate the need for using FEL. FEL is always useful when in situations where ETTL II will be fooled (lots of reflective surfaces, lots of white, lots of black, etc). Bob
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Feb 01, 2008 23:13 | #10 Sonno wrote in post #4833847 This has been driving me nuts! Say I'm in Av or Tv mode. If I meter off one part of a scene with the flash up, and hit the * button to lock the exposure, when I go to recompose the exposure settings change. Why does it do this? I thought Flash Exposure Lock was supposed to lock in the exposure. It doesn't matter what CFn4-1 option I have my 40D set to, it does the same thing. Am I missing something here? If you have the flash mounted and turned on, hitting the "*" button will lock the flash exposure (assuming the "*" button hasn't been reassigned to focusing) as you would expect it to do. Now, when you go back to recompose the frame, you say that you're seeing the exposure settings change. That's also very likely. But here's the thing. When the flash exposure is locked, you won't actually see that in your viewfinder other than to have the "*" icon light up. The shutter speed and aperture settings you see in the viewfinder, in Av or Tv mode, is for the ambient light metering which does not necessarily have to lock unless you're in Evaluative metering and OneShot modes or C.FnIV-1 has been set to 3. ...Leo
SESmithJr Senior Member 566 posts Likes: 2 Joined Jan 2008 Location: Florida More info | Feb 01, 2008 23:35 | #11 PacAce wrote in post #4834192 If you have the flash mounted and turned on, hitting the "*" button will lock the flash exposure (assuming the "*" button hasn't been reassigned to focusing) as you would expect it to do. Now, when you go back to recompose the frame, you say that you're seeing the exposure settings change. That's also very likely. But here's the thing. When the flash exposure is locked, you won't actually see that in your viewfinder other than to have the "*" icon light up. The shutter speed and aperture settings you see in the viewfinder, in Av or Tv mode, is for the ambient light metering which does not necessarily have to lock unless you're in Evaluative metering and OneShot modes or C.FnIV-1 has been set to 3. I'm using the internal flash. -Steve
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Feb 01, 2008 23:52 | #12 Sonno wrote in post #4834303 I'm using the internal flash. So there's a difference between exposure lock and flash exposure lock. Gotcha. Pardon my ignorance, but what exactly does FEL do and why would I need to use it? Thanks! FEL, as the name implies, locks the flash exposure and works basically the same way AEL works to lock ambient exposure. And the application is the same, too, i.e. to get a better exposure by locking the exposure on something closer to mid-toned, like a part of the subject or some other object nearby, if the subject is too dark or too bright. If what you FEL on is not part of the subject, it needs to be the same distance from the flash as the subject is because, as we all know, the brightness of the flash light is inversely proportional to the square of the distance to the subject. ...Leo
| Latest registered member was a spammer, and banned as such! 1741 guests, 168 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
