Thread started 29 Jan 2008 (Tuesday) 05:15
out of focus eyes does this matter??
OSCAR ­ DISS
Jan 29, 2008 05:15 |  #1
hi i have been playing around in a friends studio recently but i am having trouble getting the eyes in focus does this matter????
this is a tipical example of my results what would you have done to get this correct or better??
JoYork
Jan 29, 2008 05:38 |  #2
How were you focussing? Did you choose an AF point, let the camera decide or focus manually?
The image can probably be sharpened up with a little tweaking but it's generally best to get them right on camera if you can.
Jo
OSCAR ­ DISS
Jan 29, 2008 05:49 |  #3
yes i use the af but i always try to make it focus on the eyes i really struggle with it!!
JoYork
Jan 29, 2008 05:57 |  #4
It can be tricky. I tend to choose the best AF point I can for the shot. Stepping down the aperture helps immensely and if you're in a studio then you'll have plenty of light to work with.
Stepping down not only gives you more depth of field (so more things are in focus) but it also gives you sharper images - most lenses become sharp between f/5.6 and f/8
Jo
OSCAR ­ DISS
Jan 29, 2008 06:14 |  #5
ok thanks for the info!! i shall go try it out i can not remember what i had the aperture on in this pic i have a feeling it may have been around 4.0 or something!
JoYork
Jan 29, 2008 06:22 |  #6
Ah I've just looked at the exif info and found out what the problem was.
The aperture you used was f/8 which is good, but the shutter speed was only 1/10 of a second which is way too slow. You really need to increase the shutter speed - try increasing your ISO from 100 to 400 and then see how sharp the image comes out.
Jo
OSCAR ­ DISS
Jan 29, 2008 06:32 |  #7
ok i just checked out the af and it was on f8 1/10 so should i still be having the problem ????
OSCAR ­ DISS
Jan 29, 2008 06:33 |  #8
my camera was a 5D and the focal lenth was 105mm
OSCAR ­ DISS
Jan 29, 2008 06:34 |  #9
oh ok thank you!! so faster shutter speed it is then thank you :o)
SwingBopper
Jan 29, 2008 07:36 |  #10
I'd suggest you manual focus and use a tripod. 1/10 is pretty slow too I'd agree. But with a still subject it can work if you're on a tripod and trigger with a timer or a remote switch.
EOS 5D II, 40D, Sony R1, Olympus 1030, Canon S5-IS.
"Those who stand for nothing fall for anything." A. Hamilton
GDHugh
Jan 29, 2008 12:25 |  #11
Agreed, Even on a tripod you need to stay above 1/60s because your subject will move every so slightly causeing an unshape image.
David
G.D.Hughes Photography
Titus213
Jan 30, 2008 01:42 |  #12
Leave the f-stop at f8.0, crank the shutter up to 125 and boost your strobe output a bit. This is really very simple and should not require a tripod or higher iso. Shoot ISO 100.
And yes, out of focus eyes matter a whole bunch....
Dave
Perspiring photographer.
YippieYeah
Jan 24, 2011 03:35 |  #13
I have same problem. Its not the best studio lights arent the greatest and its very tiny.
Im not happy with these 2(f13 1/160):
http://www.riccardo-ulpts.com/IMG_0913.jpg (external link)
http://www.riccardo-ulpts.com/IMG_1197.jpg (external link)
But id say this one is ok (f7.1 1/160):
http://www.riccardo-ulpts.com/IMG_9710.jpg (external link)
And im very happy with the sharpness with this one (f10 1/160)
http://www.riccardo-ulpts.comIMG_0637.jpg
Its a Canon 1000D with the lens that comes with it... thinking of getting a sigma 30mm 1.4 soon.
Maybe you guys could help me.
Canon 550D + Tamron 17-50mm + Canon 50mm 1.8 II
1,656 views & 0 likes for this thread, 6 members have posted to it.
2125 guests, 127 members online
