Thread started 30 Jan 2008 (Wednesday) 16:21
Before and after # 15
thekid24
pro-zack-lee
Jan 30, 2008 16:21 |  #1
Oh wow I got it!
This game is to help those of us who are trying to learn new tricks when it comes to editing.
Here's the break down of the game. I will post a picture, that I choose, resized to exactly 800 pixels maximum on the long side. Outside of being resized it has to be unedited...meaning no adjustments to any levels, it has to look like it did as it came out of the camera.
The game will last 48hrs and whoever can produce the best edited image (as judged by me) will be picked and it'll be their turn to post their unedited picture for all of us to take a crack at.
The participants must have there "Image Editing OK" turned on and they must provide at least a simple breakdown of how they edited the image, some entrants are a little vague on this point, please give us all details so we can learn and share tips. For instance if you use the unsharp mask tool or Smart Sharpen provide us with the adjustments you used so others can try them out.
Also, please keep all comments, be it positive or negative, to yourself until after the game has ended.
If you happen to be the winner of the a game please start the next one with the title of the game and the following number. For example…the next game should read (Before and After # 16.)
This is all about having fun so have at it!!!
This game will end on February 1st, 2008 @ 10:00pm central
EL ­ Photo
Jan 30, 2008 18:22 |  #2
here is my feebile attempt. I need lots of practice in photoshop...
http://ellislloyd.com (external link)
http://ellislloyd.com/​blog (external link)
http://facebook.com/el​lislloydphoto (external link)
BitterSweet
Jan 30, 2008 20:38 |  #3
Well I really liked the fog in the background so tried to focus alittle more on that. I hope this isn't too dark on some monitors.
- Duplicated layer
-Added Contrast and darkened it a bit
-Duplicated layer again (original) added monday morning filter
-added alittle bit of blue
-Added vignette and border
Tracey McCloskey
www.Bitter-Sweet-Photography.com (external link)
Model Mayhem Link http://www.modelmayhem​.com/bittersweetphotog​raphy (external link)
SilverHCIC
Location: Swimming, cycling or running ... somewhere in California
Jan 30, 2008 22:55 as a reply to  @ BitterSweet's post |  #4
I liked the setting of this shot, and I found the lighting challenging. It seemed like early morning to me, so I wanted to add some emphasis to the sun. Here's my interpretation:
1) Straightened horizon 1/2 degree left
2) Mutiplied original layer 50%
3) Bumped contrast slightly
4) Converted to duotone via color mask
5) Added morning sun with lens flare, positioned sun behind tree
6) Softened image slightly
7) Added border with color matching duotone layer
"It's easy to find your bike in transition when you're the last one out of the ocean ... it's no fun being lost at sea :rolleyes:."
ZeroOne86
Jan 31, 2008 06:40 |  #5
I adjusted the curves, hue/saturation, a cooling photo filter, a high pass sharpening layer with the layer settings on soft light then brought down the opacity on that layer.
I used a layer with soft light settings to burn down some of the back ground trees and slightly brighten the trees in the foreground. I also did a slight surface blur and did a mask on that layer. With that I specifically painted the water to smooth it out. Finally I had a layer that I used smart sharpen.
Canon Rebel XTi 18-55mm, 50mm f1.8, 430 EX
Flo
Gimmie Some Lovin
Jan 31, 2008 10:11 as a reply to  @ ZeroOne86's post |  #6
crop
desaturate -17
glow effect -full
contrast
sharpen/blur
Flywing
Gallery: 148 photos
Jan 31, 2008 11:02 as a reply to  @ Flo's post |  #7
Crop to bring horizon to 1/3 position
re-size image - larger
Convert to BW in channel mixer
lens correction - vignette
distort - diffuse glow
stylize - diffuse - anisotropic
drop shadow
azsteve-o
Jan 31, 2008 18:44 as a reply to  @ Flywing's post |  #8
warming photo filter 94% on top/45% on bottom
curves adjustment
multiply brush and soft light brush on water
clone out tree banch on upper left corner
slight crop
sf1
Jan 31, 2008 20:56 |  #9
Thought this could use the help of HDR.
1. Opened up the jpg in CS3 bridge. Made 5 copies, -3, -1, 0, +1, +3 exposures and saved them.
2. Opened up photomatix and imported the 5 jpegs. Tone mapped them. Adjusted the temperature, saturation, white & black points, luminance. Saved this HDR file.
3. Opened the HDR file in CS3. Adjusted the sharpness using USM 15, 15, 0 and 65, 1,
4. Added a free boarder I found on another site.
Sorry for the watermark. I am still evaluating photomatix and not purchased it yet, hence the watermark.
Canon 5DII, Canon 1D Mark II N
Canon 24-70 mm f/2.8 L, Canon 85 mm f/1.8, Canon 70 -200 mm f/2.8 IS L, Canon 400 mm f/5.6 L, Canon 50 mm f/1.4, Manfrotto 055XPROB & 488 RC2
Canon Speedlites 580 EX, 430 EX II & 3 PW II, iMac I7, MacBook Pro, Aperture 3, CS5
CesarAmbriz
Jan 31, 2008 21:09 |  #10
Well this is what I came up with.
Started out by adjusting the levels. Next I went & desaturated the image, but kept the reds and yellows intact. Later I adjusted the saturation, did a high pass converted to overlay. Brought up the sharpness. Duplicated layer & played around with the exposures to create a snow effect. I brought up contrast merged all layers.
IMAGE: http://i209.photobucket.com/albums/bb50/firu3000/Beforeafter15.jpg
The goal is not to change your subjects, but for the subject to change the photographer.
erixon
Feb 01, 2008 05:00 as a reply to  @ CesarAmbriz's post |  #11
You may think im a psyko, but here are something different.
Didnt crop, you can play with format size and stuff, i didnt do it.
'Levels', played around i 'selective color' slice copy and flip vertical. levels again to bring detail forward.
I went for a more harsh edge graphic style thingy. fun fun fun!
| 5DMkII | 40D | 35L | 85L | 135L |
|flickr (external link)||Black'n White Portraits (external link)|
4hero
Feb 01, 2008 08:53 |  #12
Added Noise
Darkened Sky
Darkened River
Added Gradient on the bottom left and right corners (black to transparent)
Added Border with dropshadow and 30% white 1px stroke
Neil
Gear & flickr (external link)
[7D, 40D, 350D, RAW, always manual]
suzyb
Feb 01, 2008 11:49 |  #13
Well, not nearly as cool as some of these on here (azsteve - love your take), but here's my version:
Leveled it a tad.
Cropped.
Played with contrast and saturation. Down with red - up with green to highlight the mass of roots up front.
Some burning in here and there.
Added a frame.
I think that's it.
thekid24
pro-zack-lee
Feb 02, 2008 07:51 |  #14
it was literally a coin toss between 4hero and suzyb...and the winner is.....suzyb.
Thanks to all that participated, there were some amazing processing.
Congrats Suzy.
Flywing
Gallery: 148 photos
Feb 02, 2008 08:55 as a reply to  @ thekid24's post |  #15
Congrats to the winners! Good choice.
3,350 views & 0 likes for this thread, 13 members have posted to it.
1588 guests, 139 members online
