Thread started 01 Feb 2008 (Friday) 14:08
Glass
barrelwell
Feb 01, 2008 14:08 |  #1
A question for the more experienced,
How do I go about shooting through glass windows? as my local zoo has alot of reptiles etc behind glass.
Any help please..
Dermit
Joined Nov 2005
Feb 01, 2008 14:27 |  #2
Install a cheap rubber screw on lens hood and press it right against the glass. The closer you can get the glass to the lens (without touching the lens glass) the better of you will be. This will help eliminate any glare and also keep the window in a range where it will likely be out of focus and therefore show less detail/dirt in the image.
5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
http://www.pixelcraftp​hoto.com (external link)
gjl711
Feb 01, 2008 14:41 |  #3
I have had good luck with a rolled up piece of black construction paper. It does the same thing. Roll it into a tube just a bit longer than the lens. The paper sits against the glass shielding all the reflections.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
20droger
Feb 01, 2008 15:59 as a reply to  @ gjl711's post |  #4
If you can't get to the glass to block reflections, you can use a polarizer.
Another trick is to bring a friend in a black/very dark shirt. You can position the friend so that the only reflection is the dark shirt. This is usually much less apparent than any form of bright or light-colored reflection.
653 views & 0 likes for this thread, 4 members have posted to it.
Glass
Latest registered member is ahmed0essam
1742 guests, 175 members online
