Does the battery grip for the Canon 20D Increase your frame rate? Please let me know if you have the answer. Thanks
danielkucin Member 82 posts Joined Nov 2006 Location: Lanham, Maryland More info | Feb 01, 2008 16:25 | #1 Does the battery grip for the Canon 20D Increase your frame rate? Please let me know if you have the answer. Thanks Thanks,
AdamLewis Goldmember 4,122 posts Likes: 53 Joined Oct 2005 Location: Seattle, WA More info | Feb 01, 2008 16:27 | #2 danielkucin wrote in post #4831846 Does the battery grip for the Canon 20D Increase your frame rate? Please let me know if you have the answer. Thanks ![]() No.
i ask, becuase a guy showed my his D300 and it did actually make it about 1.5 to 2 frames faster Thanks,
Croasdail making stuff up More info | Feb 01, 2008 16:36 | #4 yep, completely different beast. The nikons are also additive batteries - it's a replacement for your existing battery but additional power.
BillRoberts revolting peasant 3,079 posts Joined Apr 2006 Location: UK More info | Feb 01, 2008 16:39 | #5 No Daniel they don't. You get more shots providing you put two batteries in, but it certainly does not increase the frame rate in any way. BiLL
jklewer Goldmember 1,292 posts Likes: 1 Joined Jan 2007 Location: 34N 118W More info | Feb 01, 2008 17:24 | #6 Now I want a Nikon... Increased frame rate? Its like having an old film body and adding a power booster
AdamLewis Goldmember 4,122 posts Likes: 53 Joined Oct 2005 Location: Seattle, WA More info | Feb 01, 2008 18:03 | #7 Croasdail wrote in post #4831894 yep, completely different beast. The nikons are also additive batteries - it's a replacement for your existing battery but additional power. Only the D300 works that way. Previous ones didnt. It requires not only the battery grip but a totally different battery also. Im not sure but Id bet it probably has a little bit more voltage on it.
alt4852 Goldmember 3,419 posts Likes: 1 Joined Oct 2007 Location: Northern Virginia More info | Feb 01, 2008 18:20 | #8 jklewer wrote in post #4832202 Now I want a Nikon... Increased frame rate? Its like having an old film body and adding a power booster if i remember correctly, the d300 usually shoots at 2.5fps and the battery grip bumps it up to like 8fps or something. 5D4 | Z21 | 35L2 | 50L | 85L2 | 135L
-MasterChief- - B E L I E V E - 3,188 posts Likes: 2 Joined Mar 2006 Location: Requiem More info | Feb 01, 2008 18:24 | #9 not entirely true. the D300 shoots at 6.5 to 8 fps when in 12-bit mode (the latter with the grip and battery combo). switch to 14-bit and it crawls to a lowly 2.5 fps.
how do you shoot at 14-bit? Thanks,
-MasterChief- - B E L I E V E - 3,188 posts Likes: 2 Joined Mar 2006 Location: Requiem More info | Feb 01, 2008 18:34 | #11 its simply a Custom Function you change in the menus. not having a 40D or a D300, i could not tell you which CF# it is. perhaps somebody else could.
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Feb 01, 2008 20:39 | #12 danielkucin wrote in post #4832624 how do you shoot at 14-bit? On the 20D, you can't. This is available in the 40D, the 1D 3 and 1Ds 3 only ATM. Jon
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Feb 01, 2008 21:56 | #13 roeddel wrote in post #4832638 its simply a Custom Function you change in the menus. not having a 40D or a D300, i could not tell you which CF# it is. perhaps somebody else could. ![]() Yes, on the D300, it's a menu option between 12-bit (default) and 14-bit. But on the 40D, it's fixed at 14-bit and can't be changed to 12-bit. ...Leo
Familiaphoto Goldmember 3,948 posts Likes: 1 Joined Jan 2007 Location: Chicago, IL More info | Feb 01, 2008 22:38 | #14 Just get the 40D and enjoy a glorious 6.5fps. Paul
6.5 frames is nice, but almost noobish lol. I get great shots at 5 frames, the 40D is not that great of an upgrade from the 20. Same autofocus system, body, and all that is not included is 2 more megs that barely make a difference, spot metering, and a bigger screen. Thanks,
| Latest registered member is MWCarlsson 855 guests, 173 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
