Thread started 01 Feb 2008 (Friday) 21:36
70-200 Color Question
djthemac
Feb 01, 2008 21:36 |  #1
I recently purchased the 70-200 2.8 IS for my XTi after reading all the rave reviews and seeing the spectacular pictures that have been posted from this lens. When it first arrived, I was like a kid in the candy store experimenting with the shallow DOF of 2.8. I was also relatively pleased with its performance at a recent wedding I took shots at.
Today I took it to Popago park, a slightly hilly park in Tempe Arizona about 30 minutes before sunset to take some shots. I was shooting RAW with sunny WB ISO 400-800 in Av mode. When I got the pictures back they didn't quite capture the color I thought i was taking. It seemed to my eye that the light was much more vivid both in the sunset and against the rocks.
With that said I wonder if it could be one or more of the following problems
1. You shouldn't use "sunny" WB early morning or late afternoon
2. Arizona is normally poop brown and lacking colors.
3. my 70-200 / XTi has issues (im pretty sure its shooter error :cry:)
Here's a couple shots, that may be able to help describe my problem.
Any insights would be greatly appreciated!
doidinho
Feb 01, 2008 23:12 |  #2
Most of you shots are in the shade, not the sun, so WB is an issue. Also, the sky is blown out, so dont expect any color there. Here is what I did with some quick PP. Next time put the WB to auto and dont blow out the sky; you will get much better color.
Robert McCadden
My Flickr (external link)
MM (external link)
5DMKII, Rebel xti, 24-105 f/4L, Canon 70-200 f/4L, Canon 17-40.
djthemac
Feb 01, 2008 23:18 |  #3
doidinho wrote in post #4834186 (external link)
Looks good! When you say "dont blow out the sky" i understand what you mean, but what is the best way to make sure to achieve that?
BradM
Feb 02, 2008 08:15 as a reply to  @ djthemac's post |  #4
Several methods to prevent blowing the sky, polarizing filter or neutral graduated filters, or a minus setting in exposure compensation can do so but at the cost (possibly) of details in the shadowed areas.
You can use your white balance setting to get warmer colors as well, AWB maybe the easist to way to go but certainly not the best. Using the cloudy orshade setting will result in warmer richer colors even in sunlight areas. But this nothing that can't be done in post processing either. The best techniques are to use a custom WB based on a grey card setting in the light you are shooting, or to include a grey card in the shot to accurately reflect the lighting and use it in post to correctly define the colors.
1,056 views & 0 likes for this thread, 3 members have posted to it.
1014 guests, 107 members online
