How do I get PhotoshopCS to retain the EXIF data in the file after I've processed it? I'd like to leave it in there for others to view, if they wish. Also, my gallery software will display it if it's available.
BlueDog Member 85 posts Joined Apr 2004 More info | Oct 07, 2004 11:43 | #1 How do I get PhotoshopCS to retain the EXIF data in the file after I've processed it? I'd like to leave it in there for others to view, if they wish. Also, my gallery software will display it if it's available.
Roger_Cavanagh Goldmember 1,394 posts Joined Sep 2001 More info | Oct 07, 2004 13:14 | #2 My guess is that you are using Save for Web, which, I think, strips the EXIF data. Use Save as JPG instead. =============
Roger_Cavanagh Goldmember 1,394 posts Joined Sep 2001 More info | Oct 07, 2004 13:14 | #3 |
aericj Goldmember 1,240 posts Joined Sep 2003 Location: Louisville, K USA More info | Oct 07, 2004 13:31 | #4 Interesting - I had the same question in Elements and I think that is exaclty my problem. Damn, I like the save for web because you can preview it. Guess I will have to go there and preview and then do save as JPEG. Thanks. Canon Ti5 w/ 18-135 IS STM, 70-300 IS, 85 1.8
Oct 07, 2004 17:35 | #5 That's exactly what I'm doing. I'll give the other way a spin and see if it works.
steven Senior Member 568 posts Joined Jul 2004 Location: Austin, TX More info | Oct 08, 2004 20:24 | #6 I was having the same problem with the save to web option (e.g. no EXIF data). 1Ds
tofuboy Senior Member 652 posts Joined Aug 2004 Location: Maple Valley, WA More info | Oct 09, 2004 01:40 | #7 When in 16 bit mode, you can't save as jpg (which are 8 bit files). You can always convert it down to 8 bit by going to image -> mode -> 8 bit. After doing that, then selecting save as, you will be able to choose jpg. -Matt Seattle Photography - Nature|Portrait|Event
| Latest registered member is Thunderstream 1015 guests, 111 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
