Thread started 03 Feb 2008 (Sunday) 13:00
differences in terms of contrast, colors, etc.?
prinspaul
Feb 03, 2008 13:00 |  #1
I am wondering this myself for already quite a long time.
Let's recall the famous 17-55 / 24-70-105 threads if you like :)
I know both 3 lenses are very sharp; comparable, if not, the same.
But I have my doubts for example the contrast and colors. Is it all about the difference between using the 24-105 on a 5d or 30d?? even compared with the 17-55? or does the 24-105 renders colors 'richer and more warm' compared with a 17-55 on for example a 30d?
I've tried to find it out myself, by looking for example at both these 3 threads:
17-55 https://photography-on-the.net/forum/showthre​ad.php?t=234558
24-70 https://photography-on-the.net/forum/showthre​ad.php?t=173736
24-105 https://photography-on-the.net/forum/showthre​ad.php?t=142974
I found that the L lenses produce, in my opinion, indeed better contrast pics with more warmth and richer colors. So is that because of the 1d/5d, or just because of the lens?
thanks in advance
edit: I'm comparing the 17-55 to these 2 L-lenses, because the 17-55 is considered as one of the top ef-s lenses. Comparing the 18-55 with the 24-70 would be useless indeed ;)
Philco
Joined Nov 2005
Feb 03, 2008 13:25 |  #2
On the same 30D body, if I swapped the 70-200 F2.8 for the 17-55 IS, the files very definitely were not as contrasty and the color was different. When I switched to the 24-70, suddenly all my files looked the same and I didn't have to apply different processing to get them to match. Maybe my 17-55 wasn't the greatest copy - it was sharp when I nailed focus, but I agree that it's not the same as what I get from L's. The color was noticebly warmer, but not in a good way - it meant that I had to process files at different WB settings to make them match.
Canon 5D MKIII/Canon 5D MKII/ 70-200 F2.8 IS L / 24-70 F2.8L / 85 F1.2L II/ 35 f1.4L / 135 F2.0L / Canon 600 EX-RT X 2
[SIZE=1]r follow me on Facebook. (external link)
TitusvilleSurfer
Feb 03, 2008 13:30 |  #3
I don't know about the 17-55, but the 70-200 is much better than the 70-300 in the color dept.
50D | G11 | 50mm f/1.4 | 70-200 f/2.8 IS | 580exII
prinspaul
Feb 03, 2008 13:53 |  #4
yes... it is said that for example the 17-55 has a so called 'L-glass' and it only lacks build quality.
But I'm having more and more the feeling it is more then only the build quality...
TitusvilleSurfer
Feb 03, 2008 15:49 |  #5
Well you do know that what makes an "L" an "L" *IS* build quality right? So to say the 17-55 is just an efs L is crap. L doesn't mean its the sharpest (although it probably puts it in a strong running). L means it is built the best, the toughest.
philthejuggler
Feb 03, 2008 16:44 |  #6
The 17-55 f2.8 that I tested was super sharp, but there was something about the shots that made me think "not quite as nice as 'L' lenses" - quite probably colour-related
Blog (external link), Website (external link) http://www.pho2u.co.uk …pher-in-northamptonshire/ (external link)
1DsIII, 5DIII, ZE21mm, 50mm 1.2, 85mm 1.2II, 135 f2, 580EXIIx2, X-Pro1x2, 18-55, 35 1.4, 60 2.4, EF-X20
prinspaul
Feb 03, 2008 16:59 |  #7
yea...I confirm that feeling. I didn't experience it my own, but just by looking at the different pics! that's why I am asking you guys out here
n1as
Feb 03, 2008 17:01 as a reply to  @ philthejuggler's post |  #8
I've seen the difference between my 24-70L and my 50 f/1.4 and 85 f/1.8 primes, with the primes delivering the better looking images.
- Keith
http://darwinphoto.zen​folio.com (external link)
JoYork
Feb 03, 2008 17:02 |  #9
The colours, sharpness and overall IQ "pop" are noticeably better on my 70-200L than the 17-55IS.
Jo
Mr. ­ Clean
Feb 03, 2008 19:50 |  #10
There is some special glass in the L lenses that give that cool color and great contrast. The EF primes do well to compare in those areas but I don't think there are other zooms out there that have the L feel.
Mike
some shots @ Zenfolio (external link)
ed ­ rader
"I am not the final word"
Feb 03, 2008 19:58 |  #11
philthejuggler wrote in post #4844307 (external link)
that was my experience too. pretty subtle but not the same.
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
prinspaul
Feb 04, 2008 03:11 |  #12
ok, thanks guys!
I was already wondering if it really was 'only' the camera :)
argyle
Feb 04, 2008 06:39 |  #13
TitusvilleSurfer wrote in post #4843964 (external link)
This is a misleading statement. Sure, L lenses are built better than the consumer line, but it goes beyond that. The L lenses also use a better grade of lens elements and coatings that produce the noted results. To say that an L is only an L because its built "the best, toughest" is not accurate to say the least.
To the OP: The better contrast and colors that you notice with an L lens are prettty much due to the lens itself, not the body. When I upgraded from the 28-105/Mk II to the 24-105L, I was still shooting with a 30D. I took some pics with each to see how the lenses compared, and while the 28-105 gave the 24-105L a run for the money, the L won out with its better contrast and colors out of the camera. After I added a 5D body, I tried the same test, with the same results. There's a reason the L's are priced as they are...its mainly because of the optics.
JoYork
Feb 04, 2008 08:18 |  #14
Also I heard the paint they use to paint the red ring with is worth more than gold :wink:
Jo
prinspaul
Feb 04, 2008 10:45 |  #15
argyle wrote in post #4847455 (external link)
That's why I am wondering if top EF-S lenses have the same optics. I know they are close...but thát close? I know not alot ef-s lenses can be compared with the L's, that's why I recalled the famous 17-55/24-70-105 threads. but maybe the differences here are marginal.
2,054 views & 0 likes for this thread, 9 members have posted to it.
1315 guests, 124 members online
