Thread started 03 Feb 2008 (Sunday) 23:18
"Best" Dell laptop for CS3?
Bob_A
Gallery: 48 photos
Joined Jan 2005
Feb 03, 2008 23:18 |  #1
I'm looking at replacing my Dell Inspiron 9100 with a new generation Dell laptop and need some advice regarding what I should purchase. My 9100 has a 3 GHz P4 with HT and 1 GB RAM and is pretty slow when trying to handle large TIF files.
I know I need more RAM, but how much? And what kind of screen should I be looking for (they seem to all be "glossy" now ... is this correct)?
I'd like to keep the price below $3K, and weight isn't an issue. It looks like I can get a fairly loaded up XPS 1530 for around $2500, but want to be pretty certain that I'm headed in the right direction since I won't upgrade again for another 3-4 years.
Any advice would be appreciated :)
Bob
Ryan ­ McDede
Feb 03, 2008 23:19 |  #2
why not a macbook pro?
Canon 30D w/ BG-E2 battery grip
Canon 24-70L usm
Bob_A
Gallery: 48 photos
Joined Jan 2005
Feb 03, 2008 23:23 |  #3
Ryan McDede wrote in post #4846158 (external link)
No, sorry not a Mac fan :)
Bob
dilorenzo1954
Gallery: 202 photos
Feb 03, 2008 23:24 as a reply to  @ Ryan McDede's post |  #4
Whatever you get, put in as much RAM as you can because CS3, like CS2 is a memory hog.
Ed
Bob_A
Gallery: 48 photos
Joined Jan 2005
Feb 03, 2008 23:26 |  #5
dilorenzo1954 wrote in post #4846182 (external link)
Is 4 GB enough? My Inspiron with 1GB really has problems.
Bob
flareak
Feb 03, 2008 23:30 |  #6
try more processing power too. 2500 for that seems pretty steep though :-/
What is L? Oh baby don't hurt me... don't hurt me... no more
Bob_A
Gallery: 48 photos
Joined Jan 2005
Feb 03, 2008 23:33 |  #7
flareak wrote in post #4846216 (external link)
The price is several hundred more than required because I added Media Center, bluetooth mouse, and a TV tuner along with some other "fluff".
Bob
bryank930
Feb 03, 2008 23:34 |  #8
Bob_A wrote in post #4846194 (external link)
Without going with a 64bit operating system, 4GB is really as high as you can go. I have 3GB, and don't have any problems at all.
*edit*: Media center is not worth the price IMO.
Canon EOS 60D | Google Nexus 7 | Samsung Galaxy S4 / SPH-L720 | Tamron SP AF 17-50mm f/2.8 XR Di-II LD ASP IF | Canon EF 85mm f/1.8 USM EF-S 55-250mm f/4-5.6 IS | Yongnuo YN-565 YN560
dilorenzo1954
Gallery: 202 photos
Feb 03, 2008 23:41 |  #9
It should be. Anything above 2 GB. I'm running 4 Gig myself on my desktop (actually 3.5 after XP has it's way). CS2 alone sucks up 533MB by itself, I would imagine that CS3 uses about the same if not more.
Ed
BigBlueDodge
Feb 03, 2008 23:44 |  #10
Of course you know, that you get much more machine for the money if you buy a regular PC instead of a laptop. $3K buys you a REALLY nice workstation, and just a decent laptop.
In my opinion RAM should be your first priority. You want enough so that everything (Windows, Photoshop, your image files) fits in RAM, and windows does not have to page to disk. There really is no reason not to do full 64bit these days. You will find that laptops generally max out at 4GB of RAM (where as workstations can hold much more). I would max out the RAM with 4GB. (Dell is pretty proud of their RAM. What you might do is get the minimum amount offered in the laptop model you are looking at, and then go to NewEgg and buy 4GB at a nice savings.)
The next priority is to make sure you have as fast a disk as possible, and that is generally 7200RPM SATA in a laptop. Because laptops are designed for portability (and thus optimized for battery life), you won't find fast disks because they use alot of juice. High end disks on laptops are just standard drives on regular workstations. Disks are orders of magnitude slower than your CPU. When your CPU has to read from disk, this is a VERY slow (relatively) request than reading from memory. It does you no good to have the fastest CPU that can't run at full speed because it spends 30% of it's time waiting for IO requests to disk to complete.
Last, you should focus on CPU. If you have a scenario where everything fits in RAM, and there is no paging to disk, then CPU will be your biggest bottle neck. Get enough to make you feel good, but don't sacrifice RAM or disk speed to get a faster CPU.
Photoshop is a 2D application, and thus does not require a strong video card. If you don't plan on gaming, then the standard video card should be fine.
I myself am not a fan of the glossy screens. With dark backgrounds, there is alot of glare and reflection going on and it's very annoying to look at. I like matte screens.
David (aka BigBlueDodge)
Gear
C.K.
Joined Jun 2005
Feb 03, 2008 23:50 as a reply to  @ BigBlueDodge's post |  #11
That 1gig you have now is a huge bottleneck. Unless you have strong reasons other than slow image processing to get another computer, try an increase of ram in your current Dell.
30D/300D and a bunch of glass
BigBlueDodge
Feb 03, 2008 23:51 |  #12
dilorenzo1954 wrote in post #4846258 (external link)
Actually, that is not XP robbing you of memory. That is the chipset on your motherboard robbing you of memory.
Gear
Bob_A
Gallery: 48 photos
Joined Jan 2005
Feb 04, 2008 00:06 |  #13
Thanks for the feedback everyone ... it's much appreciated. You've given me a lot more things to mull over :)
Bob
wilvoeka
Feb 04, 2008 01:42 |  #14
I just got a Dell Inspiron 1520 this week from the Dell Outlet for $560.
It came with a 2.2 Gig Core 2 Duo 160Gb Sata drive and 1 Gig of Ram. I bought 4 Gigs of ram from newegg for $80.
The extra ram shows up as 3.850 Gigs.
I can have music playing and Run lightroom and CS3 at the same time without any issues.
Tdragone
Joined Sep 2004
Feb 04, 2008 01:56 |  #15
I have a 9100 also.
I just re-loaded Vista on a friends Inspiron 1720 and was blown away by it's horsepower. Sad to say; but the core 2 duo's out now whoop my 9100's butt.
If you had the 9100; I doubt you'd go back to the 15" display, so the 1720 is your best choice.
I HIGHLY suggest going to the scratch and dent area for Dell. Most are laptops that are brand new and either the owner reconsidered the price, or like my 9100, was delivered damaged. Mine had a broken screen when the orig owner received it. They put a new screen in and I got it for almost 50% less when I bought it.
Get 2 gigs of ram and whatever processor you can afford. You'll have a laptop that will be as fast now as when you got your 9100 :)
-Tom Dragonetti
Spyder Holster + R5 with EF->RF adapter, 1Dmk IV, 50D, G11
10-22, 16-35 2.8Lii, , 24-70 2.8Lii, 50mm 1.4,
70-200 2.8Lii IS, 100-400L IS
1.4x TC, 580EX ii, ST-E2
9,098 views & 0 likes for this thread, 17 members have posted to it.
1396 guests, 104 members online
