Thread started 05 Feb 2008 (Tuesday) 20:45
How wide angle with Cokin P holder???
Antz_Marchin
Feb 05, 2008 20:45 |  #1
How wide of a lens can I go with before I'm going to start having a problem with using a non-wide angle Cokin P adaptor?? I'll be shopping for a wide lens once my bank account recovers from my camera package purchase but I intend to use my GND set extensively with this lens and don't want the holder to become visible when backed right out. I'm sure that 17mm is safe but wouldn't mind getting a little closer to 12 or 10mm if possible.
da_nige
Feb 06, 2008 05:56 |  #2
You can shoot 12mm but no lower. I used to use P filters with the Sigma 10-20mm(on a 20D) and after 12mm it was fine but below it you could see the filter.
I now use the Ps with my 17-40mm(on a 1D2n) and there are no problems
Neil
1DIV -- 40D -- 12-24mm f4.5-5.6 EX -- 17-40mm f4 L -- 24-70mm f2.8 L -- 70-200mm f2.8 L II -- 100mm f2.8 Macro -- 300mm f4 L IS -- 500mm f4 [COLOR=red]L IS -- 1.4 II -- 580EXII x2 -- 430EXII
Gitzo 3530LSV tripod and Manfrotto monopod, various pieces of camo gear, various filters and cables. Lowepro (x3) Dakine and Crumpler bags.
Dan ­ Doucette
Feb 06, 2008 09:29 as a reply to  @ da_nige's post |  #3
I often use the Cokin P filter system combined with a Hoya slim circular polarizer (with front threads). This way I have the CP filter that can easily be used on any lens even with lens shades, and then the P filter holder that can also be attached on top of the CP or by itself, depending on what I need. To minimize vignetting I have cut the P holder so that there is now only one slot into which a GND filter will slide (or any other filter). With this combo I get these results:
5D with a 16-35 (mkI)
No CP (or UV) filter, just modified P holder: No vignetting at any focal length.
With Hoya CP filter and modified P holder: Vignetting begins around 20.5mm.
5D with a 24-70
With Hoya CP filter and modified P holder: Vignetting begins around 27mm.
Good gear does not make great photos, you and your vision do, the gear just helps a bit.
Antz_Marchin
Feb 06, 2008 15:36 |  #4
Super, thanks guys
Tsmith
Formerly known as Bluedog_XT
Feb 06, 2008 23:40 |  #5
Canon EOS 30D + Cokin P wide angle holder and EF-S 10-22: slight vignetting in top corners at 10mm but gone around 11mm. My 350D/XT didn't have issues even at 10mm.
doidinho
Feb 06, 2008 23:59 |  #6
My xti starts to vignette at 15mm w/ the cokin wide holder and a CPL. I have not noticed any problems w/o the CPL.
Robert McCadden
My Flickr (external link)
MM (external link)
5DMKII, Rebel xti, 24-105 f/4L, Canon 70-200 f/4L, Canon 17-40.
nicshow
Jul 02, 2008 22:52 as a reply to  @ doidinho's post |  #7
Do you use the middle slot or the slot closest to the lens?
http://www.flickr.com/​photos/nicshow/ (external link)
http://www.nicshowalte​r.com (external link)
4,170 views & 0 likes for this thread, 6 members have posted to it.
2855 guests, 155 members online
