FORUMS Photo Sharing & Visual Enjoyment Wildlife
Thread started 06 Feb 2008 (Wednesday) 08:41
The "premie newbie"
iCallisto
Feb 06, 2008 08:41 |  #1
Hello everyone.
Larry ­ Weinman
Feb 06, 2008 08:52 |  #2
The second photo is excellent although some might argue that the subject is too centered in the frame. As for the first photo, I always thought that dogs shot at there own level were better then dogs shot from above. Anyway, you seem to have a good eye and once you get done learning all the controls on a DSLR I think you will do some outstanding work
7D Mark II 6D 100mm f 2.8 macro 180mm f 3.5 macro, MP-E-65 300mm f 2.8 500mm f4 Tokina 10-17mm fisheye 10-22mm 17-55mm 24-105mm 70-300mm 70-200 f 2.8 Mk II 100-400mm Mk II 1.4 TCIII 2X TCIII 580EX II 430 EX II MT 24 EX Sigma 150-600
iCallisto
Feb 06, 2008 08:54 as a reply to  @ Larry Weinman's post |  #3
Thank you!
If the object is dead in the center isnt that called Rules of Thirds? It shouldnt be in the center?
canusa
Feb 06, 2008 09:22 |  #4
Hi Sam,
Welcome to the forum :)
You've taken some very nice shots of your dog. You seem to have a good handle on your P&S right now. I agree that your "eye" for a shot, paired with a nice DSLR you will have some outstanding shots.
Here is a great place to start with for the general tips, tricks and "rules"
https://photography-on-the.net/forum/showthre​ad.php?t=52418
Just remember that every rule is also meant to be broken if the right situation comes along. But as once said by a wise moderator:
Jon wrote in post #278902 (external link)
you have to understand why the rules are there before you can safely break them . . .
Looking forward to seeing more from you.
Cheers,
Micheal Armstrong http://flickr.com/phot​os/mdaphoto/ (external link)
Gripped 5D
Gripped Rebel XT
Canon 28-135 50 1.8II 17-85IS
430EXII
Keltab
Feb 06, 2008 17:42 |  #5
Congratulations on some nice work! You do have a good eye, and that is the most important thing in photography - the cameras may give you more flexibility for different shots, but the eye and the taker is more important than the equipment. You mentioned youa re a pixel junkie... you will find many forums here and elsewhere that talk about "more pixels isn't always better"... I am new to this arena also, but I have done a ton of research - and you will find both the Canons and the Nikons get great respect in the field. Choose one you feel comfortable with, and use it as much as you can! I chose Canon and I am glad I did. The 40D would be a good choice - you might want to check it out. You can usually find a rental place where you can try different cameras to see which you like best. Good luck as you dive into photography!
The Only Difference Between Ordinary and Extraordinary Is That Little Extra :D
1,168 views & 0 likes for this thread
The "premie newbie"
Latest registered member is Coolbawncross
709 guests, 215 members online
