How wide-spread is the light coming out of a softbox? I got my hands on a 24x36 softbox, and the light is spread over more than 90 degrees (maybe even more) in front of the box. Is this normal? I read softbox are supposed to be very directional?
dr_who Senior Member 291 posts Joined Dec 2005 More info | Feb 07, 2008 16:35 | #1 How wide-spread is the light coming out of a softbox? I got my hands on a 24x36 softbox, and the light is spread over more than 90 degrees (maybe even more) in front of the box. Is this normal? I read softbox are supposed to be very directional? 5D, 50mm F1.4, Sigma 24-70, EF 70-200mm F2.8 IS
DoubleNegative *sniffles* 10,533 posts Likes: 11 Joined Mar 2006 Location: New York, USA More info | Feb 07, 2008 16:38 | #2 They can be made more directional via grids. La Vida Leica!
Feb 07, 2008 16:41 | #3 Thanks, double negative. So it is normal? What is the difference with grid only and grid+softbox then? 5D, 50mm F1.4, Sigma 24-70, EF 70-200mm F2.8 IS
Jason@MS Senior Member 487 posts Joined Jun 2007 Location: kent/Islington More info | something id recomend doing is getting a meter and metering the light coming from the box, dont forget to meter towards the position you'l be shooting from, and hold the meter level with your eye (thats what i do anyway..) http://blog.jasongoddardphotography.co.uk/
JimM Goldmember 1,656 posts Likes: 39 Joined Aug 2006 More info | Feb 07, 2008 20:50 | #5 It is pretty hard to diffuse light without spreading it. The diffusion material works by sending light off in all directions, although it isn't completely scattered and the box does control that to some extent. Grids on the outside of the face of the soft box reduce the spread into a something more like a column of light.
TMRDesign Cream of the Crop 23,883 posts Likes: 12 Joined Feb 2006 Location: Huntington Station, NY More info | This is quite normal and the angle of coverage will vary based on whether the front diffusion material is flush with the front of the box or if it's recessed. Generally, a softbox that accepts grids has recessed front diffusion material and a grid will give you ~40 degrees of spread, as opposed to not using a grid which can sometimes give you up to about 130 degrees coverage. Robert
| Latest registered member is Frankie Frankenberry 1019 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
