I am trying to work out how Lightroom works, with regard to getting images from the camera to the computer, then the way in which you would involve Photoshop with the process.
My current workflow:
1) Plug camera into computer.
2) Open EOS Viewer Utility.
3) Open appropriate folder view to show RAW files on camera.
4) Select, drag and drop the RAW files from my camera onto my image folder on the computer to copy them from the camera to the computer.
5) View and adjust RAW files in EOS Viewer Utility, then convert to TIFF.
6)Open into Photoshop to process, save TIFFs and also save for web as JPG.
I can see that you have a lot more in the way of editing features in Lightroom, so that would replace some (but not all) of the processing tasks I currently do in Photoshop. If I do some of these tasks in Lightroom that I previously did in Photoshop, is the image affected in exactly the same way as it would have been in Photoshop, or will there be differences? If I wanted to, could I treat Lightroom as a viewer utility and simply convert to TIFF to work in Photoshop? If so, I think I would probably do that to start with, then involve more of Lightroom's capabilities when I get used to it.
So, I suppose the main question is would I be able to transfer my current workflow intact, across from my present set-up to Lightroom?
Thanks very much,
Mike
