Thread started 08 Feb 2008 (Friday) 18:14
Canon 17-40L back focusses at 17mm?
-MasterChief-
- B E L I E V E -
Feb 08, 2008 18:14 |  #1
i just noticed this but my 17-40L back focusses when zoomed out to 17mm. focus gradually gets better as you zoom in. its perfect from approx. 25mm-40mm.
if i zoom to 17mm, acquire focus and take the shot, its consistenly back focussed compared to when i zoom to 40mm, acquire focus, then zoom back out to 17mm and take the shot.
any ideas? or is this by design?
gasrocks
Feb 08, 2008 18:18 |  #2
Not all zoom are parafocal. Meaning that refocus might be requirred when changing mm.
-MasterChief-
- B E L I E V E -
Feb 08, 2008 18:20 |  #3
so youre saying this is by design?
-MasterChief-
- B E L I E V E -
Feb 08, 2008 18:23 |  #4
ok i just googled what parafocal meant and no, this is not my problem. if i acquire focus at 17mm, its back focussed. if i acquire at 40mm, the focus is perfect. why is that? or is this by design?
thanks for the quick reply btw.
Calzinger
Feb 08, 2008 18:33 |  #5
I see what you mean, and I actually intended to make a thread addressing this. It's a habit I've developed whenever I use a zoom. I always zoom in all the way, acquire focus on the subject, and then zoom out as necessary to compose. I never compose before focusing just because it seems like there's more room for error for the autofocus at the shorter ends of zooms.
Now I don't know if your 17-40L is back focusing at the short end or not, but it seems like focusing at the shorter end of zooms isn't as accurate. Then again, I suppose that just makes sense.
"That building in the background is distracting."
"Oh OK, I'll move it out of the way next time."
internet forum fail
-MasterChief-
- B E L I E V E -
Feb 08, 2008 18:43 |  #6
thanks chris. yeah its weird. ive tested this phenomena on my 30D and 5D and both exhibit the same behavior with the 17-40. im wondering if this is by design.
never noticed this issue on my other zooms.
wimg
Feb 08, 2008 18:55 |  #7
roeddel wrote in post #4879709 (external link)
I don't have this issue with my 17-40, neither on the 350D or 400Ds I owned, and neither on my current 40D.
However, I focus differently with this lens, especially for landscapes, than I do with any longer lens.
I focus 1/3 the way into the object I want in perfect DoF. That does the trick every time. Oh, and it does focus correctly with a test chart.
I use the same technique with my EF-S 10-22.
HTH, kind regards, Wim
-MasterChief-
- B E L I E V E -
Feb 08, 2008 19:02 |  #8
thanks Wim. you said that it focusses correctly on a test chart. does your 17-40 focus properly at 17mm? or do you have to acquire focus at a different focal length then shoot at 17mm? thanks for the reply!
Calzinger
Feb 08, 2008 19:18 |  #9
If you only notice it on your 17-40L, then your lens may have its own flaw, though I'd rather not jump to that conclusion so quickly. I would assume that your lens is parfocal, which would explain why you can zoom in to 40mm, focus, and not have any issues zoomed back out to 17mm. I don't think varifocal SLR lenses would function the same way.
Can you do two tests on a chart? Maybe one where you focused at 17mm and the other where you focused at 40mm and zoomed back out to 17mm.
internet forum fail
-MasterChief-
- B E L I E V E -
Feb 08, 2008 19:40 |  #10
i havent dont focus chart tests but real life tests prove that when i focus at 17mm - it backfocusses and when i focus at 40mm and zoom out to 17, focus is perfect.
i wonder if anybody else with the 17-40 have this problem.
bildeb0rg
Gallery: 821 photos
Feb 09, 2008 06:05 |  #11
"noobies argue about bodies, pros argue about glass, seasoned veterans let the pictures argue for themselves." Can you show us a pic of what you're getting? How close are you to the subject?
-MasterChief-
- B E L I E V E -
Feb 09, 2008 08:08 |  #12
the proof is in the pudding mah friends: this was shot at about 10" from the front battery for which focus @ 17mm was acquired.
here's a center crop:
here's one where focus was acquired at 40mm, then zoomed out to 17mm:
also a center crop:
i also did the same test at about 36" and came out with the same results. im not hallucinating am i? :(
thanks for the replies btw, if you have a 17-40 and have a few minutes to spare, would you please do the same test to verify or debunk this problem? thanks again! :)
mcmadkat
Feb 09, 2008 08:17 |  #13
OK I will test that with my 30D + 17-40L.
Cheers,
Sam
30D 17-40L 580EXII
https://photography-on-the.net/forum/showthre​ad.php?t=386249
-MasterChief-
- B E L I E V E -
Feb 09, 2008 08:32 |  #14
thanks sam!
mcmadkat
Feb 09, 2008 08:37 |  #15
Right, well I am not convinced your test methods are totally suitable, but I had a go anyway!
My lens seems fine. I set it up rested on the table, MLU, remote release. I dofocussed the lense manually then let it AF.
I did notice that if I moved from the 2nd battery to the 1st battery the AF did not refocus?
Here's the pictures, no sharpening other than in camera.
Don't know how useful that it, I do enjoy an investigation though!
30D 17-40L 580EXII
3,138 views & 0 likes for this thread, 8 members have posted to it.
1172 guests, 136 members online
