ed rader wrote in post #4883220
i agree.....but what i think confuses people is when you read the article by thom that is so widely referred to as gospel he says you need $1k tripod.
So, you're in for a minimum of US$800, but more likely somewhere around US$1000. Thus, I've saved you a minimum of US$700 if you just opt for this approach from the beginning. i think that's BS
ed rader
I am not quite sure the classification on "BS" is appropriate.
A lot of what a person's needs in a tripod are going to depend on what they are going to put on it. If you are using 'Super Teles', you are going to be on one end, while a 70-200 f/4.0 will put you on the other. Blended with that will be how "fussy" you are about the quality of your shots, how tall you are, etc.
Once you have determined the needs for your tripod, you have the other trade offs of price and weight. For example (ignoring a quality discussion, but assuming equal) the 055XPROB legs weigh 5 lbs. To get that to ~3 lbs will cost 2 to 3 times. Worth it?....only you can make that trade off....
The 488RC2 is a good, well priced head (I still own one). While once set it will not "creep", with a 70-200 f/2.8 and , more often, a 100-400(at 400), it will, as Hogan asks "...Frame a shot with the tripod head loosened. Tighten the head down. Did your shot move?..." If you don't mind "adjusting" for that shift, you have a great ~$100 head. If you want to avoid that (and/or are using longer/heavier lenses) you will have to go for a ~$300 to $400 head. One nice addition with the better head is the friction control which will allow you to set resistance when the head is released, so it doesn't flop around.
I think Hogan is expressing what is needed for a high quality solution for tripods/heads. SkipD is recommending a "sweet spot" option for a good tripod with an attractive lower price. Does that make either of these recommendations "BS"? In my opinion, *NO*....just answers to different questions.
