Thread started 11 Feb 2008 (Monday) 02:10
ixus 950 IS or SD850 IS - how does canon get this picture?
phil.
Feb 11, 2008 02:10 |  #1
http://www.canon.co.jp …50is/sample/sam​-11-e.html (external link)
shooting mode =manual,
how do you get the shutter speed to 1/13 sec?
the lowest I can only seem to go is 1 sec. but it will go all the way up to 15.
any ideas?
think the camera is also know as SD850 IS
thanks
Jon
Joined Jun 2004
Feb 11, 2008 15:28 |  #2
That was actually a 13", not 1/13", exposure, if you check the EXIF data.
Jon
Cocker Spaniels
danpass
Feb 11, 2008 22:25 |  #3
Which, as you already found out, can be set manually.
Though for some crazy reason they didn't enable it the other way as well!
Dan
Gallery (external link) | Gear/Feedback
phil.
Feb 15, 2008 22:41 |  #4
so its normal that in manual mode you can not set the shutter speed lower than 1 sec?
this is a bit stupid isnt it?
cheers
Jon
Joined Jun 2004
Feb 16, 2008 06:03 |  #5
It's not actually "Manual". Manual would imply full control over both shutter speed and aperture, neither of which are controllable. The mode you have is "Camera M", which doesn't allow much other than ISO and slow shutter speeds. If you want shutter speed control, you need at least an A570.
Jon
Cocker Spaniels
GimpyPoop
Joined Dec 2003
Feb 16, 2008 11:13 |  #6
You can set the shutter speed to longer than 1" but can't manually chose anything for shorter shutter speeds . . .
Function > Exp > Menu > Choose shutter speed
I would go with the 950 - want it badly myself!
1,406 views & 0 likes for this thread, 4 members have posted to it.
2562 guests, 97 members online
