Anybody got some tips for me, ie what setting to use?
Those are few of mine from yesterday, they were shot ISO 400 Shutter priority and shutter speed 200 i think. I was using and would generally use the kit lens.
ANY help greatly appriciated!
Phil
penfolduk Senior Member More info | Feb 11, 2008 06:09 | #1 Anybody got some tips for me, ie what setting to use? Those are few of mine from yesterday, they were shot ISO 400 Shutter priority and shutter speed 200 i think. I was using and would generally use the kit lens. ANY help greatly appriciated! Phil ![]() Fuji X-T3
AB8ND Senior Member 745 posts Likes: 3 Joined Dec 2006 Location: Grand Rapids, MI More info | Feb 11, 2008 08:03 | #2 With the 300D I'd use the Sports Mode, which is the only way to get the Rebel in AF Servo Mode. Servo Mode will allow the camera to track the moving subject to try to keep focused. You put the center focus spot on the rider, half press the shutter, this will lock the focus on him, now keeping one of the focus points on the rider the camera will track him until you press the shutter button fully, you need to keep it half pressed for this to work. Sports Mode is the only way to get the 300D to use AF Servo even with the firmware hack.
Feb 11, 2008 08:06 | #3 You need to up the ISO in order to get a faster shutter speed. What was the light like?, you were under the trees so could you have used a faster shutter speed with 400 ISO, or you could of used flash to freeze the bike. Have a look at the photo I took, this was 400 ISO f5.6 with a little flash,
2x Canon 1D MkIII, Canon 70-200mm f/2.8L IS, Sigma 24-70mm f2.8, Canon 17-40mm f4,Sigma 10-20mm, Canon EF 24-105mm f4 L IS USM, 2x Canon 580 EX Flash,Yongnuo 565 Flash, Lowepro Magnum AW, Lowepro belt system.
Feb 11, 2008 08:33 | #4 I did use the onboard flash, mind me asking Graham, but how do you use a little flash? Fuji X-T3
Feb 11, 2008 08:34 | #5 AB8ND wrote in post #4895189 With the 300D I'd use the Sports Mode, which is the only way to get the Rebel in AF Servo Mode. Servo Mode will allow the camera to track the moving subject to try to keep focused. You put the center focus spot on the rider, half press the shutter, this will lock the focus on him, now keeping one of the focus points on the rider the camera will track him until you press the shutter button fully, you need to keep it half pressed for this to work. Sports Mode is the only way to get the 300D to use AF Servo even with the firmware hack. Sports Mode also automatically sets the iso to 400 also and unless you have the hack sets the record to jpg. Jack Cheers Jack I will try that. Fuji X-T3
willyb Cream of the Crop 6,433 posts Likes: 1 Joined Feb 2007 Location: London More info | Feb 11, 2008 12:27 | #6 Right mate! What you need to do is up the iso to get a faster shutter speed! Then if you know where the riders are going to be then you could manual focus on the point! I don't bother doing that, but with the kit lens (which is a little slow at focusing) you may need to! Gear List & 2012. A Photo a day.
Feb 11, 2008 21:59 | #7 penfolduk wrote in post #4895321 I did use the onboard flash, mind me asking Graham, but how do you use a little flash? I have a 580ex flash mounted on the hotshoe. You can turn the flash power down to 1/2 or 1/4 or 1/8 power 2x Canon 1D MkIII, Canon 70-200mm f/2.8L IS, Sigma 24-70mm f2.8, Canon 17-40mm f4,Sigma 10-20mm, Canon EF 24-105mm f4 L IS USM, 2x Canon 580 EX Flash,Yongnuo 565 Flash, Lowepro Magnum AW, Lowepro belt system.
Feb 12, 2008 05:13 | #8 oh right thanks lol wasn't trying to be cheeky just curious. Fuji X-T3
SnlpeR Goldmember 1,013 posts Joined Dec 2007 More info | i would either pan...
| Latest registered member is griggt 1306 guests, 134 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
