Thread started 13 Feb 2008 (Wednesday) 11:49
Winter work
slimninj4
Feb 13, 2008 11:49 |  #1
Working out my new lens. Trying to figure it out. This photo is really soft and I am not sure why. Also would like to know what is wrong with it and what is good with it. You won't hurt my feelings. I just want to improve.
I did do some PP. There was a blue tint so I corrected that I think as much as I needed. Also tried to make the trees stand out a bit more. The original was very drab and blue.
Canon 40D 5Dm3 || 24-70 L 70-200 2.8 IS2 100mm Macro 50mm 1.8 35 1.4
CHICAGO-N
Feb 13, 2008 19:53 |  #2
background is distracting, subject seems to far away, snow is over exposed, her face is dark. winter is tricky for shooting pictures though.
It's not your equipment, its your ability.
setcode
Feb 13, 2008 21:04 as a reply to  @ CHICAGO-N's post |  #3
static composition
slimninj4
Feb 14, 2008 10:38 |  #4
Your right the background is very distracting. I guess adding more DOF would help? I will try to put it back in LR to see if I can brighten only the face.
Setcode can you explain what you mean? :-) I think I will stick with indoor shots. My outdoor shots continue to look like snapshots.
snails
"I used the last of it to tip the strippers."
Feb 14, 2008 10:56 |  #5
Looks like you missed the focus. It appears to be on the tree in the background, while your subject is soft.
Otherwise the photo is not particularly interesting. There's too much "nothing" going on in the background to have it in focus.
Your image can chosen for the Best Of gallery only if it is in your own member gallery.
Sam
Feb 14, 2008 12:22 |  #6
I looked through your gallery and after that along with this shot my advice is to not worry so much about exposure or DoF and work on composition a little.
I like to try and convey how I see the subject in my shots. Make some eye contact with them through the lens and really grab the viewer. Try different angles.
Watch how they move while they are just sitting and talking to you, what features or mannerisms do you notice? Try and capture those through posing.
It looks like you have plenty of models to practice on! You said you wouldn't have hurt feelings so I am being honest. Keep working and asking for help here. There are a ton of great people photographers here.
SilverHCIC
Location: Swimming, cycling or running ... somewhere in California
Feb 14, 2008 14:23 as a reply to  @ Sam's post |  #7
When shooting in snowy conditions, white balance is often thrown off because the camera will attempt to use the prevalent white areas as neutral gray. Two things will help: 1) Set exposure compensation to +1 or more. 2) Shoot in RAW so you can correct WB later.
"It's easy to find your bike in transition when you're the last one out of the ocean ... it's no fun being lost at sea :rolleyes:."
leninglass
Feb 14, 2008 18:20 |  #8
Looks like a shot from a point and shoot. Take advantage of your cameras control.
Canon 5D Mark III x2 - 14mm Mark II f/2.8 L II - 24 L II - 35mm f/1.4 L - 50mm f/1.2 L II - 70-200 f/2.8 L II IS - 100L Macro - 600EX-RT x3
Lenin Glass - One of Oklahoma's Premier Wedding Photographers (external link)
1,558 views & 0 likes for this thread, 7 members have posted to it.
Winter work
891 guests, 118 members online
