Thanks for the replies!
I hadn't looked at ND Grad filters before, so I just spent some time researching them here on POTN. In order to help fellow newbies that may be reading this thread too, I learned that a graduated neutral density filter works by stopping down the light so you can better expose for areas that would normally be blown out. For example, on a landscape scene where the foreground is not as bright as the sky. Without a ND grad filter, you could blow out the bright sky when you expose for the darker foreground. But a ND grad filter allows you to stop down the bright sky, allowing for a better exposure in relationship to the foreground. I learned that you can slide the filter around to position it in the frame where needed. I also learned that you can buy a ND grad with a soft or hard edge. This simply defines the area on the filter that transitions from the stopped down light to the part on the filter that is not stopped down at all. And last but not least, there are different filters for controlling how much light is stopped down. (1 stop, 2 stops, or 3 stops)
I do have a couple of questions:
1) Is there any way to achieve a similar effect in post-production?
2) Are square ND grad filters the best way to go? (I saw some round ones on B&H)
3) Does anyone have a picture of the contraption that holds the square filters on their camera and in-use?
4) Are they a hassle to use?
Thanks!
Bryan
