Is anyone having trouble with its Canon G3 Remote Control?
Mine no longer works
I obviously changed the battery... I can see that the remote emits
some light signal but cant make my G3 to response to it.
It did work fine before...
Help !
Max
maximegousse Hatchling 4 posts Joined Oct 2004 More info | Oct 14, 2004 11:40 | #1 Is anyone having trouble with its Canon G3 Remote Control?
RalphM Mostly Lurking 16 posts Joined Sep 2004 More info | Oct 14, 2004 11:48 | #2 Bad Remote
BrianTilley Member 160 posts Joined Jul 2003 Location: Central New Hampshire More info | Oct 14, 2004 13:23 | #3 Max,
mrsmac Junior Member 24 posts Joined Oct 2003 Location: New Zealand More info | Oct 15, 2004 17:15 | #4 Mine died too, after about 6 months - so it was a warrently replacement, but I had to be pretty persistent to get it (in New Zealand). It took over 2 months to get the replacement.
tamadite Hatchling 2 posts Joined May 2007 More info | May 24, 2007 15:42 | #5 I have the same problem but my camera is out of guarantee.
mrsmac Junior Member 24 posts Joined Oct 2003 Location: New Zealand More info | A new remote fixed the problem - so one assumes....
tamadite Hatchling 2 posts Joined May 2007 More info | I changed the battery of the remote and PROBLEM SOLVED! The most misleading point was to see the diode emitting light as if everything was Ok but it was not! The battery was too weak.
GordonSBuck Senior Member 914 posts Joined Jan 2003 Location: Louisiana More info | Jul 02, 2010 20:03 | #8 With my own G3, I changed batteries very regularly before finally giving up and buying a cheap generic remote. For a while, the generic seemed to have better performance but I eventually gave up on it as well. Canon appears to have dropped the wireless remote (none available for my G9 anyway) so I assume that there were fundamental problems. Gordon
hennie Goldmember More info | Jul 09, 2010 10:10 | #9 Mine is as dead as yours....
photofun23 Hatchling 2 posts Joined Jul 2010 More info | Jul 09, 2010 21:36 | #10 It helps to flip your canon cameras manual open and find solutions to the problem. Going through the pages is time-consuming but it's worth it, though.
| Latest registered member is Thunderstream 2110 guests, 94 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
