If I have a lens that is say f4-5.6 does that mean that is the range that I should only set in my camera? Im confused
blogs Member 229 posts Joined Feb 2008 More info | Feb 14, 2008 22:20 | #1 If I have a lens that is say f4-5.6 does that mean that is the range that I should only set in my camera? Im confused
Mark_Cohran Cream of the Crop More info | Feb 14, 2008 22:26 | #2 blogs wrote in post #4921174 If I have a lens that is say f4-5.6 does that mean that is the range that I should only set in my camera? Im confused ![]() No. That's the max aperture available to you at the short end of the zoom range (f/4) and the long end of the zoom range (f/5.6). You can use any aperture you like between the max and min aperture consistent with the exposure you desire. Mark
Canonswhitelensesrule Goldmember 3,648 posts Likes: 13 Joined Jan 2008 Location: Surrey, B.C. More info | Feb 14, 2008 22:28 | #3 No. It's obviously a zoom lens, so it means that the maximum aperture of the lens at the "short" end of the zoom range is f4, while at the "long" end of the zoom range, it's f5.6. Photographers do it in 1/1,000th of a second...but the memory lasts forever!
Cool, soooooo basically I can use ANY aperature I want so long as Im not at the short or long end of the zoom range? Why is that?
Mark_Cohran Cream of the Crop More info | Feb 14, 2008 22:42 | #5 blogs wrote in post #4921228 Cool, soooooo basically I can use ANY aperature I want so long as Im not at the short or long end of the zoom range? Why is that? Well, that's sort of right. You can use any aperture consistent with the exposure conditions (light, shutter speed, ISO) up to the minimum that the lens is designed to allow. Mark
Sooo if my lens has a max aperture of 4.5 even though I can set f11 on my camera I should stick to 4.5?
Tumeg Goldmember 1,823 posts Joined Nov 2007 Location: Orange County, California More info | Feb 14, 2008 23:52 | #7 I think your confused, bigger aperture means a smaller number, smallest aperture, means a larger aperture | Canon 5D Mk II | Canon 17-40MM F/4L | Canon 50MM F/1.4 | Canon 85MM F/1.8 | Canon 580EX II |
HuskyKMA "Now what?" 1,749 posts Likes: 1 Joined Feb 2008 Location: Castle Rock, WA More info | Feb 15, 2008 00:52 | #8 Okay, say you have a 70-300mm f/4-5.6. blogs wrote in post #4921293 Geee Portland-what time is it over there? Im sitting at work on a lovely sunny Friday afternoon, its 15:47 and Im hanging to go home and take some photo's!!! Only one and a half hours to go!!!It was 8:42pm when he posted that. Canon 40D w/ BG-E2N Grip| 400mm f/5.6L | 70-200mm f/2.8L IS II | 28-135mm f/3.5-5.6 IS | 10-22mm f/3.5-4.5 | Gitzo GT3541LS w/ RRS BH-55
| Latest registered member is EBiffany 743 guests, 105 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
