OK, I'm going through an image as I type... For the "bugs" someone tell me if they've figured any of these out - it's too early to know if they are bugs or lack of knowledge.
DO NOT set a directory in Bibble, exit, and then delete the directory. Well, it's not a catastrophe, but it took some mad clicking and hunting and poking to get the browser to browse *any* directory. I have no idea how I got it back.
Can't seem to find a way to reset a single tool back to the original settings. That sucks. Oops, found it in the drop-down menu next to the palettes title. Cool.
I wish Crop had some aspect-ratio settings like everyone else. Oops, found it under Tools... Basic... Rotate/Crop... Crop to... Custom. Can't seem to define a new ratio, but that's better.
When you select a new setting (like Sharpening strenght) Bibble updates the picture with the setting under the cursor whether you've clicked on it or not. I don't like that.
And I wish that *any* of these RAW editors would adjust a setting in the background and *then* show the updated image. Waiting for the image to redraw means that you can never really compare two settings. Ideally it would be cool to instantaneously flip back and forth between two options. So if you had a temp of 4900 set, and then chose 5100, there'd be a button to flip back and forth between these two settings *instantaneously* to allow a good comparison. It's just simple BitBlts to save the previews in a couple of buffers...
Picture Options... Auto Level is cool. Works well on my test image that's for sure.
Cool, you can choose output size. That can be handy.
I'm liking the Tools palette and how you can pick and choose and collapse.
Hmmm... No prompt to overwrite an existing image when saving. Kinda odd. But the second save certainly went a whole lot faster!
OK, done. Very minimal processing in PS, but it's here (at 158 KB!):
https://photography-on-the.net/forum/showthread.php?t=45644
I'm liking Bibble. If Capture One doesn't get their act together with the 20D I may just spring for the extra money and start Bibbling from now on. (That would kinda suck though.)
Edit: Playing with crop some more. The histogram doesn't update and base itself on the crop area - instead it stays the same, showing the histogram for the entire image. That *sucks* IMHO.
